BT.com
Wishlist
Buffalo 3TB DriveStation USB 2.0 Desktop Hard Drive
Delivery
Standard Due date unavailable
Buffalo's DriveStation USB 2.0 Hard Drive HD-LBU2 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space.
Get more storage instantly by simply plugging in Buffalo's DriveStation™ USB 2.0 Hard Drive HD-LBU2 to a PC or Mac via a USB port. The Buffalo DriveStation™ is a quiet external hard drive in a black glossy chassis that looks stylishly sleek whether you place it upright or flat. Its adaptive design allows efficient use of space.
Auto functions
The DriveStation™'s auto installation and auto power on/off features make it easy to use, and provide an economical solution where you can quickly store, access, and transfer files, digital images, documents, and backups.
  • Compatible Interfaces: USB 2.0 Interface - connects to USB on any PC or Mac
  • Pre-formatted drive: Ready to use, anytime
  • Connect and go: Easy to use and setup, simply plug it into the USB and play; no drivers required
  • USB Interface: Standard Compliance USB 2.0, Connector Type USB Type B, Number of Ports1, Data Tansfer Rates Max. 480Mbps (USB 2.0 Mode)
  • Dimensions (WxHxD) 38.7 x 122.6 x 189mm
  • Weight 950g
  • OS SupportWindows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
BUFFALO DriveStation - hard drive - 3 TB - USB 2.0
Hard drive - external ( desktop )
3 TB
USB 2.0
Power Source
Included AC adapter
Enclosure Colour
Glossy black
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
United Kingdom
2 years warranty
3 TB
USB 2.0
Internal Drive Interface
Serial ATA
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Max Data Transfer Rate
480 MB/s
Expansion & Connectivity
1 x USB 2.0
Power Source
Included AC adapter
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption
12 Watt ( active )
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Enclosure Colour
Glossy black
United Kingdom
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Buffalo 3TB DriveStation USB 2.0
Reviewed by Les on 26/04/2013
I have been using Buffalo for years & have never had a problem. This drive is great for the price & does not make too much noise. Data transfer is fast & is easy to use. I have not dropped it yet so don't know if it can survive a fall (my other buffalo drives could take a drop). I did have to format it before use though. Highly recommend Buffalo for storage. Thanks BT & Buffalo
3* LOUD!!!!
Reviewed by Anonymous on 03/02/2013
Good value, good brand, just plug it in and away you go - but say "goodbye" to quiet computing.
My god this thing is loud - a constant low whirring drone - even if its not in use. I pull the power cable out of it when its not being used just to get some peace. Whilst I will store some things on it, I might have to transfer the files I need onto my computer each time just so I can then unplug it. It really is loud and annoying. Shame.
Scroll to top
