BT.com
Wishlist
Buffalo 2TB LinkStation Live NAS
Delivery
Standard Due date unavailable
Store the data on your computer, along with photos and videos taken with your smartphone and camera in LinkStation™ Live while sharing them with family wherever they are. Not only sharing data but also you can enjoy watching videos saved on the NAS on networked TV at home. When you are out, it is possible to upload photos taken with your smartphone meaning you can share photos immediately with family. This NAS is sure to become the family's central home appliance.
Buffalo™ WebAccess gives you to access to your NAS via the Internet, with your smartphone, tablet or laptop. WebAccess is highly useful for downloading and uploading data from remote locations.
This NAS includes a Timer ON/OFF function that powers the drive only during programmed time periods. This prevents wasting electricity when the user forgets to turn off the NAS, You can program up to three timer settings. This cuts down on energy waste that results from leaving the power is on after office hours, on days of, or anytime the drive isn't needed.
  • Product Description Buffalo Linkstation Live 1TB NAS
  • Capacity 2TB
  • Networking Ethernet, Fast Ethernet, Gigabit Ethernet
  • HDD Interface SATA
  • Number of drives 1
  • Standard Compliance IEEE802.3ab/IEEE802.3/IEEE802.3u Standard (1000 BASE-T/100 BASE-TX/10 BASE-T)
  • Connector Type RJ-45
  • Data Transfer Rates 1000/100/10Mbps
  • Networking TCP/IP
  • OS Support Windows® 7, Windows Vista®, Windows® XP, Windows® 2000, Windows® Server 2008(R2),Windows® Server 2003(R2), Mac OS 10.7, 10.6, 10.5, 10.4, 10.3.9
  • Dimensions (WxHxD) 150 x 175 x 45mm
  • Weight 1.1 kg
See The Buffalo Technology Linkstation NAS Drives In Action!
BUFFALO LinkStation Live - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
15 cm x 4.5 cm x 17.5 cm
1.1 kg
Storage Controller
SATA - SATA 3Gb/s
Hard Drive
1 x 2 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Server 2003 R2, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Windows 8, Windows 8.1
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
15 cm
4.5 cm
17.5 cm
1.1 kg
Storage Controller
SATA - internal
Interface Type
SATA 3Gb/s
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, NTP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
iTunes server, Buffalo Web Access, BitTorrent Client, Apple Time Machine compatible
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED, UPnP
1 x Ethernet 1000Base-T - RJ-45
On/off switch
X external power adapter
24 Watt
Software Included
NovaStor NovaBACKUP
2 years warranty
Service & Support Details
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Fine as a budget NAS
Reviewed by Mr G on 31/01/2014
I bought this to use as a cheap network attached backup drive while I reconfigured my main NAS. For that purpose it worked just fine and you certainly cannot knock it for the price.
I haven't used any of the advanced features so I can't speak for them, but as a backup drive it performed perfectly adequately, albeit extremely slowly.
Shortcomings:
1. No power on/off function
2. The drive never spins down (so noisy and power consuming)
3. Very, very slow (took 36 hours to copy 750GB of data onto it, with both source and target directly connected to the router over 1m of cat5e ethernet cable)
Overall: if you want 2TB of network attached storage space to use as a temporary repository you would hard pushed to beat this on price. As your main NAS, I'd probably look to spend a little more.
3* No reset button, no power down switch.
Reviewed by Anonymous on 22/11/2012
Two months in and it did not read the default password which I didn't change yet.
I can still get at the apps and files but not any settings. So it took a few months before I get time to see to it properly
The technical phone team are very helpful but it took me three phone calls to successfully receive the instructions via email to reset user profiles. That didn't work so they ran me through everything on the phone I am back now for another 2TB hard drive to back all the 68% of used data before I can go ahead with a full factory reset.
You cannot shut the unit down without the password so I fear doing damage to the unit while its like this.
3* Many modern features, can be slow
Reviewed by Anonymous on 11/02/2013
Its very cheap to run. Until the update months in we could not pause or rewind DLNA server, only on android. instead snailed it using a USB stick. Tech Support Desk are friendly, patient and helpful, Buffalo service, No silly dial1bots and within the UK! stressless second to none. It can be really slow to acess the control panel. Could not shutdown, or lights out. Disk error needs replacing. But now that we can pause I cannot wait for the replacement, it should just be so easy and low energy via my phone or TV
Scroll to top
