Click to visit BT.com
BT.com
Wishlist
Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Quicklinx: 7PY8WS00
Mfr#: HD-LX2.0TU3-EU
Form Factor: 3.5"
Capacity: 2TB
Interface: SuperSpeed USB
£66.14
SuperSpeed USB 3.0 hard disk drive
DriveStation™ Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 RPM drive. With USB 3.0, digital content transfers at speeds of up to 5Gbps*. If you haven't moved up to USB 3.0 yet - DriveStation™ Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Features and Benefits
  • SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates of up to 5 gigabytes per second*, ideal for video and other dataintensive digital content
  • TurboPC EX utility: TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility for Windows. Now saving, copying, and transferring files is even faster.
  • High speed 7,200 RPM hard disk: The disk reads and writes data faster, so you spend less time waiting when transferring and saving files
  • Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access on Windows PCs
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
  • RAMDISK virtual disk utility: The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory)
  • eco Manager: Eco minded power management tool for Windows regulates power usage, conserving energy and battery consumption
  • SuperEco: saves power consumption during stand-by mode by Auto Power OFF
  • SecureLock Manager: Easy software simplifies access for you while keeping others out on Windows PCs
  • Plug & Play Connectivity: Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
  • Fully backwards compatible with USB 2.0: No adjustments are needed, just plug into any USB 2.0 port
  • 2-Year Warranty
BUFFALO DriveStation Velocity - hard drive - 2 TB - USB 3.0
Hard drive - external ( desktop )
2 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Hardware Full Disk Encryption (FDE), automatic backup , 256-bit AES
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
Europe
2 years warranty
2 TB
Hardware Encryption
USB 3.0
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption
18 Watt ( active )
Software Included
Buffalo Tools
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Plug and Play
Europe
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption Bundle deal on Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£76.13
7PY8 C2G 4 port USB 3.0 SuperSpeed Hub In Stock £72.90
7PY8 C2G 2m USB 3.0 A Male to Micro B Male Cable In Stock £7.06
7PY8 C2G 3m USB 3.0 A Male to Micro B Male Cable In Stock £4.56
Resources
The following resources are available for the Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Form Factor: 3.5"
Capacity: 2TB
Brand: Buffalo
Price Range Inc VAT: 50 - 100
