BT.com
Wishlist
Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
Price Crash! Week Special, Was £109.99 - Save £10!
1 on order, delivery delayed
Delivery
Standard Due date unavailable
Buffalo's DriveStation USB 2.0 Hard Drive HD-LBU2 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space.
Get more storage instantly by simply plugging in Buffalo's DriveStation™ USB 2.0 Hard Drive HD-LBU2 to a PC or Mac via a USB port. The Buffalo DriveStation™ is a quiet external hard drive in a black glossy chassis that looks stylishly sleek whether you place it upright or flat. Its adaptive design allows efficient use of space.
Auto functions
The DriveStation™'s auto installation and auto power on/off features make it easy to use, and provide an economical solution where you can quickly store, access, and transfer files, digital images, documents, and backups.
  • Compatible Interfaces: USB 2.0 Interface - connects to USB on any PC or Mac
  • Pre-formatted drive: Ready to use, anytime
  • Connect and go: Easy to use and setup, simply plug it into the USB and play; no drivers required
  • USB Interface: Standard Compliance USB 2.0, Connector Type USB Type B, Number of Ports1, Data Tansfer Rates Max. 480Mbps (USB 2.0 Mode)
  • Dimensions (WxHxD) 38.7 x 122.6 x 189mm
  • Weight 950g
  • OS SupportWindows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
BUFFALO DriveStation - hard drive - 2 TB - USB 2.0
Hard drive - external ( desktop )
2 TB
USB 2.0
Power Source
Included AC adapter
Enclosure Colour
Glossy black
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
United Kingdom
2 years warranty
2 TB
USB 2.0
Internal Drive Interface
Serial ATA
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Max Data Transfer Rate
480 MB/s
Expansion & Connectivity
1 x USB 2.0 - mini-USB Type B
Power Source
Included AC adapter
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption
12 Watt ( active )
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Enclosure Colour
Glossy black
United Kingdom
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Resources
The following resources are available for the Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* buffalo 2TB usb2
Reviewed by john on 17/02/2012
I thought i would have had problems as reading other reviews i have Window 7 64bit, just turned my computer on plugged all the cables in and presto it notice the drive first time and the software too, i have put some of my files on no problems up to yet , i still have to do my computer backup then see if that works okay, very easy to use , not to big or bulky, only time will tell, but BT.com excellent service, recieved within 3 days, up to yet well recomend this, and up to yet i did not have to unplug this and restart my computer , my other hard drives i had to do this, i think its worth looking at i can only give my review for my use
5* Buffalo 2TB Drivestation
Reviewed by Mike on 04/09/2012
I have had 3 of these (though one is the 1TB model) since February. One is attached to an iMac (easily reformatted), one to extend the capacity of a Buffalo Linkstation NAS and one to provide local storage to a WD TV-Live box. All three have worked faultlessly. However,do be aware that there is no on/off switch (which for me is not a problem), so they are not perhaps perfect for all applications.
5* buffalo 2 tb
Reviewed by leadshot on 19/10/2012
great drive straight out the box.same as my other buffalo drive still going 2yrs.delivered within 3 days.excellent service from BT.
3* Buyer beware
Reviewed by Anonymous on 08/04/2013
got this drive a few months ago, it experiences daily use but doesn't have huge amounts of data written to it. It's sadly dying on us as i type this. I've given the product itself a rating of 3 to refelect the failure (i had expected this to last atleast a few years!)
Scroll to top
