BT.com
Wishlist
Buffalo 2TB (2 x 1TB WD Red) LinkStation 421DE 2-Bay NAS
Delivery
Standard Due date unavailable
Buffalo Technology's LinkStation 421DE is the next generation two bay NAS enclosure: the 421DE features easy setup, an intuitive interface, and a free personal cloud for remote access from anywhere via web browsers or smart devices.
Buffalo's LinkStation has the latest CPU with a generation Dual Issue CPU core for noticeably improved performance that delivers very fast transfer speeds - up to 100 MB/s! And when fully populated the LinkStation 421DE can be configured in RAID 0 for performance or RAID 1 for redundant storage as part of a back-up solution.
Not only will users be impressed with the speed of Buffalo's LinkStation 421DE, they will also appreciate the intuitive interface. With quick and direct access to settings, and optimized content presentation, the LinkStation 421DE smoothly guides users through easy set up and administration. From the default landing page users will find quick links and toggles to commonly used features which have better wizards, explanations, and graphics; and suddenly, NAS administration is no longer the chore it once was!
NAS users will appreciate consolidating their media files and data in one central location; and current NAS users will appreciate faster transfer speeds, expanded capacity, and more features. All users will appreciate Buffalo's free personal cloud for remote access via smart devices or web browsers keeping all your data at your fingertips no matter where you are.
Buffalo Technology's LS421DE provides highly customizable network attached storage with greater flexibility. Users can start by installing one drive and add another - when and if needed - to easily increase your network's capacity and capability.
BUFFALO LinkStation 421 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
8 TB
2 (installed) / 2 (max)
8.7 cm x 20.5 cm x 12.8 cm
800 g
1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 1 TB SATA 3Gb/s
Network adapter 10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
8 TB
8.7 cm
20.5 cm
12.8 cm
800 g
Enclosure Colour
Sleek grey
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 1 TB
Interface Type
SATA 3Gb/s
Network adapter
Network / Transport Protocol
TCP/IP
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x USB 3.0 - Type A
External power adapter
48 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
