BT.com
Wishlist
Buffalo 2TB (2 x 1TB) LinkStation Duo RAID 0/1
Delivery
Standard Due date unavailable
The LinkStation™ Duo is a high performance, multimedia, shared RAID network storage solution for the home and small office that requires a central location to share data files, photos, video and music.
The unit is a two drive NAS solution that can be configured in RAID 0 for performance or RAID 1 for redundant storage. In addition to the storage capabilities, stream multimedia to a PC, a Mac, a Buffalo™ LinkTheater™ and other DLNA CERTIFIED™ or UPNP media player, as well as sharing movies, photos and documents in a home or small business network via the Internet with the WebAccess feature. The LinkStation™ Duo seamlessly integrates with iTunes® and allows access to music files from your iTunes® software.
With features such as enhanced performance of up to 40MB/s, quick swap via the front panel with two removable drives and easy set-up via a simple web interface, the LinkStation™ Duo is the perfect solution to store, save & share your digital life from one central place.
Easy to stream. Easy to share.
Stream multimedia from your LinkStation™ Duo to a PC, Mac and any DLNA™ or UPnP® Certified media player. Or share movies, photos and documents with friends and family on your home network or with people on your small business network. Conveniently store, access and share via the Internet through Buffalo's Web Access feature.
Quick swap drives
The two removable hard drives are easily accessible via the front panel.
Quick and easy setup
The built-in DNLA™ Media Server allows you to share movies and play music on any DLNA™ or UPnP® Certified media player.
Faster streaming speed
With data transfer rates of up to 40MB per second, expect an enhanced performance.
Listen to your favourite hits from iTunes
The LinkStation™ Duo seamlessly integrates with iTunes® and allows you to access to your favourite playlists from your iTunes® software.
  • Quick swap - 2 drive, 2 bay Network Attached Storage
  • Supports RAID levels, 0, 1 and Standard
  • Active Directory Support: Works as a client in an Active Directory domain allowing the LinkStation™ Duo to utilise the domain users and groups.
  • Apache web server, full featured enhancement modules included
  • PHP5 Scripting language, fully supported by the web server
  • MySQL database with phpmyadmin interface
  • WebAccess - allows you to store, share and access files from any web browser via PC, Mac or iPhone
  • In-Built DLNA/UPnP CERTIFED™ media server - for easy playback of multi-media files to any DLNA certified device
  • Schedule backups to a USB storage device or another Buffalo Network Attached Storage device.
  • In-Built BitTorrent™ Client
  • Supports Apple® Time Machine Back-up with multiple clients
  • Supports Apple® Bonjour®
  • Integrates with iTunes®
  • Auto Power ON/OFF with your PC or MAC
  • Eco Friendly scheduled Power Saving Mode
  • One touch transfer of media files from digital camera/camcorder with Direct Copy feature
  • Easy to install and set-up
  • 10/100/1000 Gigabit Ethernet port
  • 1 USB port
  • Supports UPS connectivity via USB port
  • Supported OS: Windows7 (32/64bit), Windows® Vista™, Windows® XP, Windows® 2000, Windows MCE 2005/2004, Windows Server 2008/2003, MAC OS X 10.3.9 or later
  • 2 Year Warranty
  • Includes NovaBACKUP® Professional with 5 licenses - protects data on workstations locally or online. Regardless of theft, user error or hardware failure NovaBACKUP® protects and restores your data.
See The Buffalo Technology Linkstation NAS Drives In Action!
BUFFALO LinkStation Duo - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
2 (installed) / 2 (max)
8.6 cm x 20.4 cm x 12.7 cm
2.3 kg
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1
Hard Drive
2 x 1 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Microsoft Windows 2000, Microsoft Windows 2000 Server, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.5 - 10.8
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
8.6 cm
20.4 cm
12.7 cm
2.3 kg
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1
Hard Drive
HDD
2 x 1 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, NTP, FTP, SMB
Remote Management Protocol
HTTP
Network Services Compatibility
Apple Bonjour Protocol, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP
iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
1 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
X external power adapter
26 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.64
£14.40
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.68
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.87
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Simplicity Itself
Reviewed by Anonymous on 04/05/2010
I was pleasantly surprised at how easy this NAS was to install and configure as my company archive, highly recommended.
3* Not As Straightforward as I'd like
Reviewed by Tony on 25/04/2014
I bought this mainly to back up my CD collection.I use a MACbook Pro.I'm competent,but found the whole set up complicated.The manual has not been well thought out - the username and password for the device don't appear until over half way through, by which time I'd already contacted Buffalo Support twice.I found the user interface clunky and non inuitive.It might be the Mac but I found that tracks went missing during transfer and some lost their tags/track info etc.which is next to useless for archiving.Using the torrent feature to move music to the NAS was a very complicated process, and nothing like using other torrent services.Tracks still went missing and my Mac had to be on and in contact with the NAS or the process stopped.PC users with this NAS have said they had the same problems.I haven't had the guts or the patience to attempt to set it up for internet sharing.In future I'll be using it for storage only, I can't rely on it for the purpose intended.It's also extremely noisy.
Scroll to top
