BT.com
Wishlist
Buffalo 1TB MiniStation Thunderbolt + USB 3.0 2.5" Portable Hard Drive
Buffalo 1TB MiniStation Thunderbolt...
£115.10
10 in stock
£115.10
Add to wishlist
Delivery
Standard 1-3 working days
Great portable storage solution: Thunderbolt (10GBps) Interface. Two times faster Interface speed than USB 3.0.
Buffalo Technology's MiniStation Thunderbolt Portable HDD is world's first portable Thunderbolt with an USB 3.0 dual interface external drive solution. The Thunderbolt (10 GBps) Interface is twice as fast than USB 3.0 while pr serving backward compatibility with existing devices that support USB 2.0 or USB 3.0.
Apple friendly
The MiniStation Thunderbolt™ Portable HDD can be formatted to support both PC and Mac® making it a great portable storage solution for any device. Native Compatibility with Mac OS X Time Machine also makes it an ideal solution for backup with Mac computers.
Bus powered
Bus-powered, the MiniStation Thunderbolt™ Portable HDD requires no additional power supply and is easy to carry. Just plug the portable HDD body with the included Thunderbolt Cable* onto your Mac. Housed in a sleek aluminum body with a transparent frosted top, the design feels luxurious. MiniStation Thunderbolt™ Portable HDD features an indirect disk access LED indicator on the underside that tastefully illuminates its supporting surface.
With the MiniStation Thunderbolt™ Portable HDD on the move, you can transfer digital content faster, simplify connections between devices, maintain compatibility with nearly any device and enjoy new ways to use portable storage.
*No AC adapter is required
  • Ultimate speed: Thunderbolt (10GBps) Interface. Two times faster Interface speed than USB 3.0.
  • Dual-interface: Two extremely fast interfaces: Thunderbolt and USB 3.0.
  • Cables included: Thunderbolt and USB 3.0 cables in the box.
  • Bus powered: No additional power input required.
  • Apple friendly: Ready for use for Mac immediately and Works for Mac TimeMachine (HFS+ formatted).
  • Design: Sophisticated design.
Specification
  • HDD Interface: SATA
  • Capacity 1TB
  • Connector TypeThunderbolt (Mini DisplayPort)
  • Data Transfer Rates10Gb/s
  • Connector TypeMicro-B USB
  • Standard ComplianceUSB 3.0
  • Data Transfer Rates5Gb/s
  • Dimensions (W x D x H)80.5 x 130 x 22.5 mm
  • Weight 260g
  • OS Support Thunderbolt - Mac OS X 10.6 or later, USB - Mac OS X 10.5 or later, Windows 7 (64-bit/32-bit) / Vista (64-bit/32-bit) / XP(32-bit)
  • Operating Environment5-35°C, 20-80% (non-condensing)
  • Power Supply USB bus powered
BUFFALO MiniStation Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
1 TB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus, Thunderbolt bus
80.5 mm x 130 mm x 22.5 mm
260 g
Apple iMac; Mac mini; MacBook Air; MacBook Pro
1 TB
Internal Drive Interface
Serial ATA
80.5 mm
130 mm
22.5 mm
260 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B , 1 x Thunderbolt - Mini DisplayPort
Power Source
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.5 - 10.8
1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
5 °C
35 °C
20 - 80% (non-condensing)
Apple iMac , Apple Mac mini , Apple MacBook Air , Apple MacBook Pro
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* SPEED!!
Reviewed by Anonymous on 02/10/2013
Whoever has the thunderbolt connection port available, get this! data transfer speed is great. Copied over a few VMs totalling 25GB in less than 5 minutes. Build quality is great, although the device is a bit on the heavy side. Price is reasonable considering that average 500GB USB3 HDD costs around £50-70. Well happy with this purchase.
5* Excellent for the price
Reviewed by Anonymous on 11/02/2014
Very pleased with this drive. Just works, and from a power perspective shuts down when not in use or when I sleep the Mac - got it connected over Thunderbolt but presume the same would happen over USB3.
Tried it connected with either interface and get 79M/s which is reasonable for a 2.5" drive so unlike the other review with unrealistic expectations I think it's a fair speed.
Ultimately this is cheap enough that if you wanted more speed you could just replace the drive with an SSD and I'm sure it would be super-fast.
1* Avoid - sloooooooow transfer speeds !!
Reviewed by Alastair on 08/10/2013
I bought this drive to move my 600Gb Aperture photo library off my desktop Mac and let me use the library on a couple of other Mac laptops.
I knew that at the price, it wouldn't have an SSD drive in it, but I had high expectations from the marketing that I was going to see significantly improved speeds from my usual external disks....how naive I was.... The drive, even in Thunderbolt mode won't crack 100Mbps.
I fired up a disk speed tester and tested the other drives that are in my Mac Mini i7 setup… (note my late 2011 Mini doesn't have USB3 ports....but it does have Thunderbolt)
Internal
Samsung SSD 256Gb 840 Pro - 474 Write and 517 Read with 150Gb used
WD SATA 1Tb internal drive - 94.9 Write and 96.0 Read with 241GB used
External
Samsung 1Tb USB3 ext drive - 31.2 Write and 36.3 Read with 148GB used
Toshiba 3TB USB3 ext drive - 30.8 Write and 37.0 with 270GB used
WD 2TB Firewire ext drive - 33.0 Write and 37.8 Read with 1.23 TB used
And, of course the mighty "up to 10Gbps speeds"….
Buffalo 1TB Thunderbolt - 76.8MB/s Write and 78.5MB/s Read with 646GB used
Hardly a life-changing speed gain is it - and certainly misleadingly optimistic to even mention Gbps speeds - what was the point ? The advertising on the product box is really just describing the potential of the Thunderbolt cable technology, not the actual disk product.
The advice from Buffalo was that given the library size, these are OK speeds and to see the best possible speeds, I should take the Aperture Library off the disk and retest it...so that would leave it as an empty external disk....or paperweight.
I don't think that the way this product has been marketed is any credit to Buffalo and I personally, will be very, very wary of purchasing or recommending another Buffalo product.
The web is full of similar experiences with it - the only redeeming feature is that it has freed up a USB slot - and - once 1TB SSD drives become more reasonably priced, the case can be cracked open and the platter drive swapped out.
Scroll to top
