Click to visit BT.com
BT.com
Wishlist
Buffalo 1TB MiniStation Plus USB 3.0 2.5" Portable Hard Drive (Slim / Shock Proof) Black
Quicklinx: 7PZSWS00
Mfr#: HD-PNT1.0U3B-EU
Ultra-portable hard drive offers maximum mobility: Buffalo MiniStation™ Plus delivers up to 5 Gbps ultra fast transfer speeds.
Store, backup or transfer your files anytime with the ultra-portable Buffalo MiniStation™ Plus - a high performance USB 3.0 portable storage in a compact and lightweight shockproof chassis. This USB 3.0 portable hard drive which is backwards compatible with USB 2.0 - works with any PC or Mac®, providing interface speeds up to 5 Gbps.
MiniStation™ Plus offers high performance USB 3.0 portable storage in a compact and lightweight shock proof chassis. With USB 3.0 support and backward compatibility with USB 2.0, it works with any PC or Mac®, providing interface speeds up to 5Gbps*
MiniStation™ Plus occupies minimal space and it's USB powered so there are no additional cables to manage and no need for a separate power source; simply plug it into any available USB port on your computer and instantly add capacity or store files to take on the road. With available 256-bit AES hardware encryption, you can easily protect your data from unwanted access by simply assigning a password. Store, back up and transport your content with SuperSpeed plug and play connectivity.
Features and Benefits
  • Compact and Lightweight: Super slim, lightweight chassis saves space for ultimate portability with a stylish, sophisticated design
  • USB Powered: Perfect companion for your laptop or netbook - no external power supply needed
  • Shock Absorbing Chassis: Shock protection elements help protect the hard drive from accidental bumps and drops
  • SuperSpeed USB 3.0 with TurboPC: Enhance the overall performance of your PC and increase file transfer rates up to 3X over USB 2.0 hard drives
  • Native USB 3.0 and USB 2.0 compatible: Support for legacy USB 2.0 and SuperSpeed 3.0
  • Connect & Go: Preformatted hard drive is ready for immediate use with Windows®
  • Hardware Disk Encryption: Optional 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access
  • Buffalo Tools: A feature-rich software suite of tools designed to boost PC performance and enhance your digital life
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
  • Time Machine® Compatibility: Works perfectly with Time Machine to back up your Mac computer
  • eco Manager: Eco minded power management tool regulates power usage, conserving energy and battery consumption
  • 2-Year Warranty
  • Capacity: 1TB
  • Interface: Standard Compliance USB 3.0 / USB 2.0 / Connector Type Micro-B type / Interface Speeds Max. 5Gbps* (USB 3.0) Max. 480Mbps (USB 2.0)
  • Dimensions (WxHxD mm) 82 x 118 x 19
  • Power Consumption Max 2.7W
  • Power Supply DC 5 V (USB powered)
  • Client OS Support Windows® 7 (32-bit/64-bit), Windows Vista® (32-bit/64-bit), Windows® XP, Mac OS® X 10.4 or later**
*5 Gbps is the maximum interface rate derived from the specifications of the Universal Serial Bus 3.0. Actual transfer rate will vary depending upon environmental factors. * *works with MacOS as normal external hard drive; included software and hardware encryption are not compatible.
2.5"
1 TB
Hard Drive / Interface
SuperSpeed USB 3.0
Resources
The following resources are available for the Buffalo 1TB MiniStation Plus USB 3.0 2.5" Portable Hard Drive (Slim / Shock Proof) Black
