BT.com
Wishlist
Buffalo 1TB LinkStation Mini RAID 0/1
Delivery
Standard Due date unavailable
The first Network Attached Storage product in the world using 2.5" hard disks! The Auto Power on / off function enables the LinkStation to turn off automatically when you shut down the last PC or laptop with installed NAS Navigator software. So small and compact that it fits perfectly in the palm of your hand, with features such as 60% lower power consumption, fanless operation and low noise make the LinkStation Mini the ideal storage solution for anywhere in your home.
BUFFALO LinkStation Mini - NAS server - 1 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
1 TB
2 (installed) / 2 (max)
8.2 cm x 4 cm x 13.5 cm
0.5 kg
Storage Controller
RAID - SATA 1.5Gb/s - RAID 0, 1
Hard Drive
2 x 500 GB SATA 1.5Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
1 TB
8.2 cm
4 cm
13.5 cm
0.5 kg
Enclosure Colour
White
Built-in Devices
Print server
Storage Controller
RAID - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1
Hard Drive
HDD
2 x 500 GB
Interface Type
SATA 1.5Gb/s
Spindle Speed
5400 rpm
Network / Transport Protocol
TCP/IP, AppleTalk, SMB
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, Server Message Block (SMB)
LDAP support, Buffalo Web Access, BitTorrent Client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
RoHS
X external power adapter
17 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
2 years warranty
Service & Support Details
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.08
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.50
£13.60
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.86
Scroll to top
