BT.com
Wishlist
Buffalo 12TB (4 x 3TB WD Red) TeraStation 4400 NAS
Delivery
Standard Due date unavailable
Buffalo's TeraStation enclosure joins Buffalo's TeraStation family with customizable Network Attached Storage with greater flexibility users can start by installing one drive and add up to three additional drives as storage and back-up requirements grow.
TeraStation 4400 is equipped with the powerful Intel Atom dual-core processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
The TS4400 also provides important features to support your business such as Active Directory support, IP camera recording, iSCSI target, a faster and easy-touse interface, and fast DDR3 memory installed. All of this, together with two Gigabit Ethernet ports, two SuperSpeed USB 3.0 ports and two Hi-Speed USB 2.0 ports, gives users a fast, versatile, and feature-rich NAS enclosure.
BUFFALO TeraStation 4400 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
Max Supported Capacity
16 TB
4 (installed) / 4 (max)
17 cm x 23.1 cm x 21.6 cm
4.75 kg
1 x Intel Atom D2550 (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 3Gb/s
Network adapter 10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
16 TB
17 cm
23.1 cm
21.6 cm
4.75 kg
Built-in Devices
Status LCD
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 3 TB
Interface Type
SATA 3Gb/s
Network adapter
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Trunking, LDAP support, print server, DFS support, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
DLNA CERTIFIED
Expansion Bays
4 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
Device-to-device data replication
Internal power supply
86 Watt
Software Included
NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license)
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
Scroll to top
