BT.com
Wishlist
Buffalo 12TB (4 x 3TB) DriveStation Quad USB 3.0
Delivery
Standard Due date unavailable
Huge Capacity Direct Attached Storage Fully populated with high-reliability WD Red™ drives
Buffalo Technology's DriveStation™ Quad (HD-QHU3 series) is a 4-bay Direct Attached Storage device perfect for demanding SMB. The HD-QHU3 comes fully populated with high-reliability WD Red™ drives in total capacities of up to 24TB.
The DriveStation™ Quad is RAID-enabled for customised redundancy and capacity depending on your specific needs and also comes with 10 licenses of NovaStor NovaBACKUP Business Essentials software.
The DriveStation™ Quad features the capacity, redundancy, and performance required for any demanding user - the perfect solution for backing up large servers, multimedia files, or databases. The HD-QHU3 series is sold fully populated with WD Red drives and total capacities of 8, 12, 16, or 24TB.
BUFFALO DriveStation Quad USB 3.0 - hard drive array
Hard drive array
Total Array Capacity
12 TB
Max Supported Capacity
24 TB
USB 3.0
4 (installed) / 4 (max)
Supported Drives
SATA-300
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, 5, 10, JBOD
Hard Drive
4 x 3 TB HDD SATA 3Gb/s - hot-swap
Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Android 2.3 or later, Microsoft Windows Server 2012 (32/64-bits), Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows Phone 8, Microsoft Windows RT 8.1, Microsoft Windows RT 8, Microsoft Windows Phone 7.5
AC 120/230 V - 50/60 Hz
14.9 cm x 23.3 cm x 15.4 cm
5.5 kg
3 years warranty
Hard drive array
Chassis
4
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
12 TB
24 TB
HDD Array External Interface
USB 3.0
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 3 TB
Interface Type
SATA 3Gb/s
Expansion Bays
4 (total) / 0 (free) x hot-swap
1 x USB 3.0 - 9 pin USB Type B
Software Included
Buffalo Tools, SecureLockMobile, NovaBACKUP Business Essentials (10 licences)
Plug and Play
External power adapter
90 Watt
14.9 cm
23.3 cm
15.4 cm
5.5 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
