BT.com
Wishlist
BT Video Baby Monitor 7000
Delivery
Standard Due date unavailable
Top features
  • 3.5" colour Touchscreen LCD display with 480x320 resolution
  • HD Sound for crystal clear audio so sensitive you can hear your little one breathing
  • Temperature Display lets you know how hot or cold it is in the nursery
  • 19 Lullabies including classical, nursery rhymes, white noise, nature and womb sounds
The BT Video Baby Monitor 7000 gives you peace of mind when your baby is resting or sleeping peacefully. There are a host of features to help your baby drift off to sleep and let you get on with things.
Double Resolution Touchscreen
The 3.5 inch touchscreen has a fantastic 480x320 pixels resolution. This is double the number of pixels of our previous video monitor, the BT Video 1000. This means you'll have a much better, clearer view of your little one. The display is so advanced, there is even a smartphone style automatic brightness setting. This is great for evenings when you don't want to be disturbed by a bright screen.
Lullabies, nature sounds & white noise
The 19 built in lullabies feature classical music and traditional nursery rhymes - from Mozart to `Twinkle, twinkle'. It also a white noise generator with specially tested sounds that help babies sleep including ocean waves, simulated womb sounds and even a hairdryer.
HD Sound and Talk Back
Like the other monitors in BT's range, the BT Video 7000 has crystal clear HD sound and a talk-back feature. The two way talk-back allows you to calm your baby when you're not in the room, while the Hi-definition Sound is sensitive enough to pick up babies breathing.
Night light
Once your baby is asleep, you won't want to wake him or her up. The adjustable nightlight allows you to find your way around baby's room without having to turn on the main light.
Invisible Infrared Lights
Unlike some video monitors, the night vision lights on the baby unit of the BT 7000 are completely invisible when it is dark. This means it's sure not to disturb your child.
Huge Range
It has a huge range of up to 50m indoors and 300m outdoors, so you can be sure to always be in contact as you move around your home.
Other features
The parent unit uses Micro USB for its power cable. This is handy as it means you can also charge it with most other Micro USB chargers. Other features include a mute function, crying alert, low battery alert and out of range alert. There is wall mountable and we even include screws in the box.
Up to 4 cameras at once
The BT Video 7000 supports up to 4 cameras at once. You can watch all 4 on split screen and then easily see one full screen if you hear a noise. The sound feed cycles between each camera or you can choose to switch sound manually between cameras.
So why BT for your baby monitor?
BT has a long history with baby monitors. Our previous monitors have won almost every award under the sun, including the prestigious Which? Best Buy, Mother & Baby Gold and Prima Baby & Pregnancy Platinum.
BT has been the bestselling digital audio baby monitor brand every year since 2010 (Source: NPD 2013).
The BT Video 7000 was designed in the UK. We work with real mums and dads throughout our product development to make sure we get the product just right.
So when you want to watch TV or make the dinner in the other room, but want total reassurance that your baby is safe and sound in the cot, the new BT Video Baby Monitor 7000 is the Baby Monitor for you.
1 Year Warranty
Resources
The following resources are available for the BT Video Baby Monitor 7000
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Good product, but range is a problem!
Reviewed by Anonymous on 22/02/2015
Great product features, easy to use, camera has good picture, would love to have kept. However max. range I could get was 12m. I thought the problem could have been my house so also bought baby monitor 300 which has same advertised range and this works perfectly between all rooms in my house. I don't know whether we just had a faulty product, but when I tried to query this to decide whether to exchange or refund I was just offered a refund.
Scroll to top
