BT.com
Wishlist
BT Mini Wi-Fi Home Hotspot 500 Kit
£59.98
£59.98
Add to wishlist
Delivery
Standard Due date unavailable
Works with any Broadband provider
BT's Mini Wi-Fi Home Hotspot 500 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband at home.
What does BT’s Mini Wi-Fi Home Hotspot 500 Kit give you?
Connect any wired or wireless device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Mini Wi-Fi Home Hotspot 500 Kit, you are able to connect any wired or wireless devices wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Mini Wi-Fi Home Hotspot 500 Kit supports all your online needs.
Simple to use
BT’s Mini Wi-Fi Home Hotspot 500 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience.
Make the most of your Broadband
BT's Mini Wi-Fi Home Hotspot 500 Kit from BT offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, generating Wi-Fi where your router doesn't reach or high speed streaming throughout your home, BT's Mini Wi-Fi Home Hotspot 500 Kit can be used to help make the most of your broadband at home.
Compatible with other technologies
BT's Mini Wi-Fi Home Hotspot 500 Kit works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with any existing Powerline network. The Mini Wi-Fi Home Hotspot 500 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV200 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Not the right Broadband Extender for you?
BT has a whole range of Broadband Extenders to meet your requirements. Whether you don't want to lose a socket, need to connect multiple devices or prefer to connect wirelessly, BT has the solution.
3 Years Warranty
Other bundles
£59.98
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£63.46
Resources
The following resources are available for the BT Mini Wi-Fi Home Hotspot 500 Kit
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* wi fi help
Reviewed by james crawford on 19/08/2016
I bought one of the hotspot 500, first class, tried to buy another extender separately, but you do not even list this part, pity, as this, would be really be very useful.
5* mrs
Reviewed by Anonymous on 26/02/2016
5
5* Mini Wi-Fi Home Hotspot 500 Kit
Reviewed by Tim Bailey on 23/12/2015
An excellent problem and exactly what it says in the description. Pity you cannot buy additional hotspot items.
5* Absolutely Brilliant
Reviewed by Peter on 17/11/2015
Exactly what I hoped it would be. I can now set up a remote WiFi hotspot throughout my house or even in the garage at the bottom of the garden. The facility to clone the SSID and password is an unexpected feature that makes this unit absolutely brilliant. Well done BT.
5* bt mini home hotspot
Reviewed by Craig on 24/06/2015
Can I use this product where the router is 30yds away upstairs and will it connect a youview box
5* BT Mini Wi-Fi Home Hotspot 500 kit
Reviewed by Rita Blasi on 17/03/2015
excellent product - easy to use and works perfectly - thanks Steve!
5* Excellent bit of kit
Reviewed by Tornirsk on 18/12/2014
Easy to set up. The wife can now watch catchup on the patio.and I can use my iPad in the conservative...bliss
Reviewed by Kevin Mc on 30/10/2014
excellent piece of kit, does exactly what it says on the tin, I now have broadband in my summerhouse at tne bottom of the garden would definitely recommend this, only negative was I thought it was £59 but charged £76 on my bill, but I am sure a call to customer services tomorrow will rectify this. installation was easy, set up was easy. no complaints at all
5* BT WI-FI HOTSPOT 500
Reviewed by Anonymous on 17/09/2014
IN THE PROCESS of PURCHASING
4* NOT BROKEN
Reviewed by egm on 21/10/2015
Ordered 12/10/14 delivered 16/10/14 and 20/10/15 they stopped working. Indicator lights including “Link” were on OK, but yesterday Ethernet connection was poor and said “No internet” or “limited Internet. Thought it was router problem but after 1.5 days replaced the BT powerline adapters with old TP-Link powerlines and system was fine again. Put the BT connectors back in place but this time “no link”. Thought they were broken one week out of warranty. They would not link again. So tried one last time and took them both to adjacent sockets and paired them again, flickered on and off a few times but eventually “Link” light stayed on. Put them back in system and Ethernet working OK again for now. These are great when they are working, so in case others are having similar problems- persevere.
Scroll to top
