BT.com
Wishlist
BT Diverse 7460 R Cordless Phone with Answer Machine
BT Diverse 7460 R Cordless Phone...
£95.98
33 in stock
£95.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
  • Phonebook Memory: 200 name and number directory; directory copying between handsets
  • Base and handset volume control
  • Ringtones: 5 standard 10 polyphonic (handset only)
  • 30 number calls list 10 Number redial list
  • SMS Facility: Yes; for SMS text messaging to work you must subscribe to a caller display service not withhold your telephone number and not bar premium rate calls
  • LCD Screen: Backlit Inverse Mono handset and base station 8 Lines
  • SIM Card Reader: SIM Card reader and writer
  • GAP compatible
  • Range From Base: Indoor range 50m Outdoor range 300m
  • Number of Handsets: 1
  • Answer Machine: 27 minutes recording time
  • Caller ID: a separate quarterly fee is payable as per SMS facility
  • Handsfree Function: yes
  • Standby Time: 180hrs
  • Talk Time: 12hrs
  • Keypad on base
  • Headset socket
  • Base settings PIN protected
BT Diverse 7460 - cordless phone - answering system with caller ID/call waiting
Cordless phone answering system with caller ID/call waiting
Cordless Phone Standard
DECT\GAP
Answering System
Digital
Intercom
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Transfer
Speed Dial Capacity
8
Display
LCD display - monochrome - Yes
Display Features
Inverted
Display (2nd)
Body Colour
1 year warranty
Body Colour
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID/call waiting
Max Handsets Supported
5
Multi-Handset Configuration
Phonebook transfer
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Type
Dual keypad
Dialer Location
Handset, base
Conference Call Capability
3-way
Intercom
Speakerphone
Short Messaging Service (SMS)
Menu Operation
Function Buttons
Speakerphone button, recall button, intercom button, auto redial button
Volume Control
Ringer Control
Ring Tones
15
Polyphonic Ringer
Handset Locator
Indicators
Low battery indicator, out-of-range indicator, visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom, phonebook transfer
Additional Features
Out of range alert, key lock, PIN code, tone control, built-in SIM card reader
Phone Memory
Phone Directory Capacity
200 names & numbers
Dialed Calls Memory
10
Speed Dial Capacity
8
Caller ID Memory
30 names & numbers
SMS Memory Capacity
Up to 40 SMS
Answering System
Answering System Type
Digital
Outgoing Announcements Qty
2
Max Outgoing Message Length
60 sec
Max Incoming Message Length
3 min
Recording Capacity
27 min
Memo Record Function
Message Counter Display
Services
Toll Saver, Call Screening
Display
Display Location
Handset
Line Qty
8
Display Information
Battery status
Backlit
Inverted
Display (2nd)
LCD display
Colour Support
Monochrome
Display Location
Base
Backlit
Aerial
Internal
Headset jack
Phone line cable
Belt clip, power adapter
Power adapter - external
2 x battery - AAA type
600 mAh
Rechargeable - Nickel Metal Hydride
Included Qty
2
Talk Time
Up to 720 min
Standby Time
Up to 120 h
Audible Battery Alert
Dimensions & Weight (Base)
14 cm
19 cm
9.9 cm
434 g
Dimensions & Weight (Handset)
5.3 cm
3.1 cm
16.3 cm
133 g
Other bundles
£95.98
Save on TP Link Smart Plug
Save £2.00
£119.95
Scroll to top
