BT.com
Wishlist
BT 8610 Advanced Call Blocker - Single
BT 8610 Advanced Call Blocker -...
Free delivery
£49.99
Free delivery
Price Drop
Limited Time Offer
SALE! Usually £59.99
£49.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The BT8600 comes with BT's unique Virtual Assistant, which means you'll never have to speak to another cold caller again*
  • Virtual Assistant screens incoming calls
  • Numbers on your contact list get straight through
  • Numbers you have blocked are rejected
  • For all other calls, the Virtual Assistant asks the caller to say their name and then asks the user whether they want to accept or block the call without speaking to the caller
  • Incorporates award winning trueCall call blocking technology
Key Features
  • Block 1000 individual numbers
  • Block calls by number and type - such as mobile, withheld, payphone, area code and international
  • One touch call blocking
  • 1.8'' Colour Screen
  • Automatically copies contacts between handsets
  • 60 minutes of messages on the answerphone
Even more advanced call blocking*
  • Block by type - choose the type of calls you want to block. For example mobile, international, withheld, unknown or payphone numbers can all be blocked. Plus you can even block numbers by area code or suffix
  • One touch call blocking - simply press the one touch button if you don't want to take the call and send the number to the blocked list
  • Do Not Disturb - For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up. Friends and family that are tagged as VIP's in your address book can still get through
Quality Built-in
  • The modern stylish design makes this phone a great addition to any room, whilst only taking up minimal space
  • Large 1.8" full graphic display. See instantly how many voice messages, missed calls or text messages you have. Large enough screen for text messaging
  • The backlit keypad makes it easy to see the keys at any time of day
Easy to use
  • Save up to 200 contacts - All these contacts are automatically copied to all of your handsets
  • Visual Voicemail - See a list of who's called you, and choose which message to listen to first*
  • Parental Control - Prevent surprises on your bill by PIN protecting calls to Mobile, International, Premium Rate numbers, or even ALL outgoing calls. Also useful for elderly relatives who rack up big bills unknowingly.
  • We've also made it easy to divert calls to your mobile or other numbers when you are away from home. Or if you want to have a 3 way call the BT 8600 helps you get it set up in a few simple steps.
Extra Answer Machine Features
  • Save up to 60 minutes of messages and see how many messages you've got displayed clearly on the home screen
  • Listen to your messages privately through the handset, or play them using the Hands-free speaker
  • Don't miss important messages when you are away from home, access your messages remotely
  • Call Waiting - Shows you who's trying to get through and at the press of a button you can switch to the new call or reject it
Freedom to Move in Your House
  • Long range of up to 300m outdoors and 50m indoors
  • Talk hands-free - letting you get on with things while you chat
  • Talk time of up to 21 hours and standby time of up to 310 hours
Need a Phone in More Than One Room?
You can get our twin, trio or quad packs should you need additional handsets for other rooms. Whichever pack you buy you will only need one telephone socket in your home to work all the handsets
What's in the (Recyclable) Box?
  • One base unit
  • One charger or more (depending on the pack size you go for)
  • Power plugs for any extra handsets
  • One telephone line cord
  • One handset or more (depending on the pack size you go for)
  • Rechargeable batteries (already fitted in the handsets)
  • A quick start guide
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT 8610 Advanced Call Blocker - Single
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Spot the difference (if any)
Reviewed by Billy on 04/07/2017
I wish to know the difference between BT 8600 and the BT8610. The price is different by about £7 BUt what else,I can't find anything, BT please let me know, why one is more expensive.
5* B.T CORDLESS PHONE
Reviewed by David on 01/07/2017
THIS PHONE IS BRILL WORTH THE MONEY THE CALL BLOCKER DO,S WORK ITS A GREAT HOME OR OFFICE PHONE BUT MORE OV A HOME PHONE IT,S GOT A MALE OR FEMALE ANSWER MACHINE,AND A COLOUR DISPLAY MANY SCREENSAVER,S AND YOU CAN TEXT TO AND RECEVES TEXT P.S TEXT ALERTS YOUR CHOICE A MUST HAVE IN THIS DAY OF AGE I COULD ON I REAMEAD THIS PHONE HI 5 BT MANY THANKS
4* Excellent ... with a couple of flaws
Reviewed by Simon on 25/08/2017
A lot of good features, but two annoying weaknesses. 1) The indicator light showing that an answerphone message has been received is very weak; it is not easy to notice and doesn't indicate the number of messages. This tiny green light is overshadowed by the bright RED light saying the answerphone is on and the even bigger BLUE light saying the electricity is plugged in! The number of messages can be seen only by manually waking up the handset from its standby mode. 2) The User Guide is incomplete. Foran explanation of all the phone's features and settings, I downloaded the guide for the 8600, an almost identical phone, whose guide is nearly double the length of this one and which includes much essential information missing from this guide (see https://www.shop.bt.com/content/uni2/documentation/bv9t/3772_bt8600_ug_[1]_call_blocking_version.pdf).
2* None Blocker
Reviewed by Anonymous on 27/08/2017
This so called Blocker. Does it really block them ? As I block them they still ring back at later date. Then voice activated message explains to them cannot take call.the BIG but is I still have to dash in from wherever I am to answer the call.to find out it has been dealt with by machine ????? Is that really progress. Also the amount of International withheld calls I am receiving is on borderline with phone abuse.which the phone cannot block.so for me BT has to come up with the technology to overcome the wasters who can withhold there number.and then call there phone up to none advanced 100% call blocker. For at the moment it's less than 50%
Scroll to top
