BT.com
Wishlist
BT 2700 Nuisance Call Blocker - Single
Free delivery
Limited Time Offer
SALE! Usually £39.99!
Select:
  • Single
Delivery
Standard Due date unavailable
BT 2700 Cordless DECT Phone with Nuisance Call Blocker
Key Features
  • Avoid nuisance and unwanted calls with our new BT 2700*
  • Block up to 50 specific numbers or use Do Not Disturb to silence your calls
  • Get the most our of your phone straight away with our easy to use menu and great sound
  • BT 2700 is available in single, twin, trio or quad handset pack sizes
Detailed Features
  • Built in Digital Answer Machine
  • Block up to 50 numbers*
  • Excellent sounds quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 12 hours of talking, 120 hours on standby
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Backlit screen
  • Redial any of the last 10 calls you made
  • 1.6 inch backlit screen
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT 2700 Nuisance Call Blocker - Single
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* An ideal phone to keep you awake at night
Reviewed by Anonymous on 22/10/2017
The irritating blue light emitted by the base units of these phones makes sure you won't get any sleep if you put one of these in your bedroom ...And there is no way to turn it off. If you DO disconnect the phone from the mains - in desperation - the phone will then bleep at you until you eventually give in and reconnect it .
This is a hopeless phone masquerading as a quality product in which not even the most basic design consideration has been given to end users. The sound quality is muffled and unclear
Scroll to top
