BT.com
Wishlist
BT 2700 Nuisance Call Blocker - Quad
Free delivery
Limited Time Offer
SALE! Usually £99.99!
Select:
  • Quad
Delivery
Standard Due date unavailable
BT 2700 Cordless DECT Phone with Nuisance Call Blocker
Key Features
  • Avoid nuisance and unwanted calls with our new BT 2700*
  • Block up to 50 specific numbers or use Do Not Disturb to silence your calls
  • Get the most our of your phone straight away with our easy to use menu and great sound
  • BT 2700 is available in single, twin, trio or quad handset pack sizes
Detailed Features
  • Built in Digital Answer Machine
  • Block up to 50 numbers*
  • Excellent sounds quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 12 hours of talking, 120 hours on standby
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Backlit screen
  • Redial any of the last 10 calls you made
  • 1.6 inch backlit screen
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT 2700 Nuisance Call Blocker - Quad
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* BT 2700 Quad phones
Reviewed by Margaret on 30/08/2016
Brilliant phone. Easy to set up, just put details in one handset and it transfers to all the others. Sound quality very good. The only down side is the lack of many ringtones, the ones available are very much the same sounding, however the last ringtone in the list is the best as it is very loud and can be heard all round the house. I wouldn't hesitate to recommend this phone even though the ring tone selection available lets it down a little.
Scroll to top
