BT.com
Wishlist
Brother RJ-4040 Rugged WiFi Mobile Printer
Brother RJ-4040 Rugged WiFi Mobile...
£540.57
Hurry, only 3 left in stock!
£540.57
Add to wishlist
Delivery
Standard 1-3 working days
When you need a portable printing solution that meets all of your workplace demands, you can rely on the rugged RJ-4040 with IP54 drop test rating for fast printing on the move.
Ultra efficient thermal technology means you're always ready to print 4" labels, receipts, quotes and invoices.
Totally dust and waterproof, the rechargeable RJ-4040 is available with a range of add-on accessories that make sure you'll get the most from this durable machine.
And serial, Wi-Fi and USB connectivity mean getting the results you need while you're out in the field couldn't be easier.
Brother RuggedJet RJ-4040 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
Portable
850 g
Max Media Size
Roll (11.8 cm)
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 x 200 dpi
USB, serial, Wi-Fi(n)
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
16 MB
Language Simulation
EPSON ESC/P, ZPL
Media Type
Labels, receipt labels
Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows CE 5.0, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Mobile 5.0 or later, Android 2.2 or later
1 year warranty
16.2 cm x 7.7 cm x 17.6 cm
Printer Type
Printer
Print Speed
Up to 127 mm/sec
Wireless
203 x 200 dpi
Language Simulation
EPSON ESC/P, ZPL
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
16 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
Media Sizes
Roll (5.1cm), Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
3000 mm
Roll Maximum Outer Diameter
58 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
1 x serial , 1 x USB
Belt clip
IP54
Software Included
Drivers & Utilities
Limited warranty - 1 year - carry-in
20 - 80% (non-condensing)
16.2 cm
7.7 cm
17.6 cm
850 g
Scroll to top
