BT.com
Wishlist
Brother QL 570 Mono Direct Thermal Label Printer
Brother QL 570 Mono Direct Thermal...
£62.89
12 in stock
£62.89
Add to wishlist
Delivery
Standard 3-5 working days
Keep everything present and correct with the QL-570, which quickly produces durable labels via your PC that can help to make sure you never misplace a file or lose important documents ever again.
This thermal address label printer delivers professional results with one click, so it's a handy solution for any business that wants to stay organised.
Simply connect to your PC or Mac via USB, design your label then print. It delivers high-quality results up to one metre in length using a continuous roll, so you can easily create everything from name badges and divider table labels through to signage and shipping labels.
Whether you're printing hundreds of labels or just one, the QL-570 offers perfect results, time after time.
Brother QL-570 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.13 kg
Max Media Size
Roll (6.2 cm)
Print Speed
Up to 68 labels/min , Up to 90 mm/sec
Max Resolution (B&W)
300 x 600 dpi
USB
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
Media Type
Labels, address labels, file folder labels, CD/DVD labels, shipping labels
Compatible Tapes
DK tape
Styles & Effects
Vertical, Mirror, rotated text
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.4.10
Microsoft Certification
Works with Windows Vista
3 years warranty
13.4 cm x 20.8 cm x 14.1 cm
Printer Type
Printer
Print Speed
Up to 68 labels/min - 300x300 dpi , Up to 90 mm/sec
Built-in Devices
Cutter
Wired
USB
300 x 600 dpi
Styles & Effects
Auto Cutter
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
Media Sizes
Roll (6.2 cm)
Max Printing Width
59 mm
Max Printing Length
914 mm
1 x USB - 4 pin USB Type B
1 x USB cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Software Included
Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
Additional Requirements
CD-ROM, USB port
Limited warranty - 3 years - carry-in
13.4 cm
20.8 cm
14.1 cm
1.13 kg
Scroll to top
