BT.com
Wishlist
Brother PTouch QL-560 Label Printer
Delivery
Standard Due date unavailable
The QL560 prints high quality labels quickly and easily, whether you need just one, or a series of labels, making it ideal to help you organize your work.
QL-560 thermal label printer from Brother enables you to quickly and easily print professional labels to suit any purpose. This high-quality device features integrated Brother P-touch technology which means it is possible to create customized and original layout for the labels.
This P-touch device offers the fastest, easiest and most versatile way to print labels directly from your PC.
Brother QL-560 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.3 kg
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 90 mm/sec
Max Resolution (B&W)
300 dpi
USB
Media Type
Labels, continuous forms
Compatible Tapes
DK tape
Microsoft Certification
Compatible with Windows 7
1 year warranty
14.6 cm x 19.7 cm x 15.2 cm
Printer Type
Printer
Print Speed
Up to 90 mm/sec
Wired
USB
300 dpi
Auto Cutter
Repeating Printing
500 copies
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (2.9 cm), Roll (1.2 cm), Roll (3.8 cm), Roll (6.2 cm)
Max Printing Width
59 mm
1 x USB - 4 pin USB Type B
Power supply - internal
Limited warranty - 1 year
10 °C
35 °C
20 - 80%
14.6 cm
19.7 cm
15.2 cm
1.3 kg
Scroll to top
