BT.com
Wishlist
Brother PTD450VP 18mm Desktop Label Printer
Brother PTD450VP 18mm Desktop Label...
£66.80
5 in stock
£66.80
Add to wishlist
Delivery
Standard 3-5 working days
From file dividers to cabinets, office equipment to name badges, having everything clearly labelled is a sure-fire way to get your workplace organised and running smoothly.
With the PT-D450VP, you can quickly generate labels up to 18mm wide, either using the printer's own PC-style 'QWERTY' keyboard and high resolution backlit display to create them direct or sending your designs via your PC. It also comes complete with its own handy carry case, 18mm black on white label tape and adapter.
Brother P-Touch PT-D450VP - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
740 g
Max Media Size
Roll (1.8 cm)
Max Media Size (Custom)
18 mm
Print Speed
Up to 20 mm/sec
USB
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Keyboard
QWERTY / 65 keys
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
18.8 cm x 17.7 cm x 7.2 cm
Printer Type
Enclosure Colour
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Preview screen, character keyboard
USB
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Auto Cutter
Keyboard
QWERTY / 65 keys
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (1.8 cm)
18 mm
Media Sizes
Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
15.8 mm
Media Feeders
1 x manual - 1 roll - Roll (1.8 cm)
1 x USB
Carrying case
1 x USB cable
Media Included
1 18 mm x 4 m black on white TZe laminated tape cassette
Power adapter
System Requirements Details
Windows Vista/7/8/8.1 - RAM 512 MB - HD 70 MB , MacOS - RAM 2 GB - HD 500 MB
10 °C
35 °C
20 - 80% (non-condensing)
18.8 cm
17.7 cm
7.2 cm
740 g
Scroll to top
