BT.com
Wishlist
Brother PT-P900W Mono Label Printer
Brother PT-P900W Mono Label...
£298.36
Hurry, only 3 left in stock!
£298.36
Add to wishlist
Delivery
Standard 1-3 working days
The PT-P900W is a complete wireless on-demand laminating label printing solution that comes with printer, accessories, label design and print software, and a full length UL certified tape - all this for the price of just the printer! This small footprint printer produces wide, premium quality laminated labels at 360 dpi print resolution, up to 32 mm print height on 36 mm tape, and features a built-in automatic cutter that trims a continuous "tape" to virtually any length, one at a time or as a strip of pre-cut labels. Brother laminated labels can withstand abrasion, fading, extreme temperatures, chemicals and moisture.
  • Create durable labels up to 36mm in width
  • High speed and high resolution printing
  • Integrated Wi-Fi to print labels from several devices at once, including tablets and smartphones
  • Advanced cutter with easy label peel function
  • Include images, barcodes and frames on your labels
  • Connect to data contained in spreadsheets to batch print many labels at once
Brother P-Touch PT-P900W - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
1.48 kg
Max Media Size
Roll (3.6cm)
Max Media Size (Custom)
36 mm
Print Speed
Up to 60 mm/sec
Max Resolution (B&W)
360 x 720 dpi
USB 2.0, Wi-Fi(n)
Language Simulation
EPSON ESC/P
Media Type
Laminated tape
Compatible Tapes
TZe tape, HSe tape, FLe label
Styles & Effects
Normal, vertical, shadow, italic, shadow light, invert
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
11.8 cm x 19.2 cm x 14.6 cm
Printer Type
Printer
Print Speed
Up to 60 mm/sec
Built-in Devices
Cutter
USB 2.0, Wi-Fi(n)
360 x 720 dpi
Language Simulation
EPSON ESC/P
Styles & Effects
Auto Cutter
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
Max Media Size
Roll (3.6cm)
36 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm), Roll (0.35 cm), Roll (0.58 cm), Roll (2.36 cm), Roll (1.77 cm), Roll (1.17 cm), Roll (0.88 cm), 21 x 45 mm
Media Feeders
1 x manual - 1 roll - Roll (3.6cm)
1 x USB 2.0
1 x USB cable
Media Included
1 36 mm x 8 m black on white TZe tape
Power adapter - external
10 °C
35 °C
20 - 80%
11.8 cm
19.2 cm
14.6 cm
1.48 kg
Scroll to top
