BT.com
Wishlist
Brother PT-H105 Hand Held Labelling Machine
Delivery
Standard Due date unavailable
Being more efficient and better organised is easy with the PT-H105, which delivers professional-looking laminated labels at the touch of a button.
From your files and equipment to your shelving units, this handheld label printer helps you to keep everything straight at home or in the office, while the lightweight design and soft touch keys means it's especially simple to use.
Offering nine font styles and a wide range of symbols, the PT-H105 also lets you design creative labels through the Deco Mode feature. You can personalise your labels by adding a frame, and even preview your work before you print.
Brother P-Touch PT-H105 - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
Portable
390 g
Max Media Size
Roll (1.2 cm)
Min Media Size (Custom)
3.5 mm
Max Media Size (Custom)
12 mm
Print Speed
Up to 20 mm/sec
Max Resolution (B&W)
180 dpi
Media Type
Laminated labels
Compatible Tapes
TZe tape
Fonts
Helsinki
Styles & Effects
Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, underline
2 line printing
Display Resolution
1 line x 12 characters
Keyboard
ABCD / 54 keys
Required 6 x AAA type Alkaline
3 years warranty with product registration
11 mm x 5.9 cm x 20.7 cm
Printer Type
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
180 dpi
Fonts
Helsinki
Styles & Effects
2 line printing
Display Resolution
Keyboard
ABCD / 54 keys
Repeating Printing
9 copies
Media Handling
Media Type
Laminated labels
Compatible Tapes
TZe tape
Max Media Size
Roll (1.2 cm)
3.5 mm
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
9 mm
Media Included
1 12 mm x 4 m black on white laminated tape
Auto on/off
No power supply
AAA type - Alkaline
Required Qty
6
Limited warranty - 3 years - carry-in
11 mm
5.9 cm
20.7 cm
390 g
Scroll to top
