BT.com
Wishlist
Brother PT-9800PCN  Labelling Machine
Brother PT-9800PCN Labelling...
£406.80
£406.80
Add to wishlist
Delivery
Standard Due date unavailable
Keeping labelling clear and consistent can be a problem when everyone is producing their own versions from different devices and printers. That's when the network-ready PT-9800PCN really comes into its own.
Now multiple users can access the same professional labelling resource, with print speeds up to an impressive 80mm per second and resolution of up to 720 x 360dpi. The labelling software is held on the network too, so there's no need to upload to every PC and laptop individually.
Particularly useful when you need to produce lots of labels at once, the PT-9800PCN is especially suited for use in manufacturing, around offices and in the post room.
Brother P-Touch PT-9800PCN - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
1.6 kg
Max Media Size
Roll (3.6cm)
Max Media Size (Custom)
36 mm
Print Speed
Up to 80 mm/sec , Up to 52 mm/sec , Up to 20 mm/sec
Max Resolution (B&W)
360 x 720 dpi
USB, LAN, serial, USB host
Media Type
Laminated tape
Compatible Tapes
TZ tape, HG tape
Styles & Effects
Bold, normal, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Compatible with Windows 7
11.6 cm x 19.3 cm x 14 cm
Printer Type
Printer
Print Speed
Wired
360 x 720 dpi
Styles & Effects
Auto Cutter
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZ tape, HG tape
Max Media Size
Roll (3.6cm)
36 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
Media Feeders
1 x manual - 1 roll - Roll (3.6cm)
Print server
1 x RS-232 , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
Power adapter - external
Software Included
Brother P-touch Editor 5
10 °C
35 °C
20 - 80%
11.6 cm
19.3 cm
14 cm
1.6 kg
Scroll to top
