BT.com
Wishlist
Brother PocketJet PJ-623 A4 Thermal Mobile Printer
Delivery
Standard Due date unavailable
Print everything from delivery notes to service reports on the move and get impressive results every time with the flexible PJ-623.
Available with a range of accessories, software and pre-loaded template options to suit your business needs, the easy-to-operate PJ-623 prints up to 300dpi. It's compact and lightweight enough to carry with you in your briefcase, but can also be mounted inside your vehicle if you'd prefer.
With USB and IrDA interfaces for seamless connectivity, it's easy to send your A4 documents to print on the spot. Plus direct thermal printing means there's no ink or toner to change, and zero risk of leakages.
Brother PocketJet 6 PJ-623 - printer - monochrome - direct thermal
Printer Type
Personal printer - direct thermal - monochrome
Portable
473 g
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 6 ppm - B/W
Max Resolution (B&W)
300 dpi
USB, IrDA
Media Type
Plain paper, continuous forms
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
1 year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Printer
Print Speed
Up to 6 ppm - B/W
Wireless
USB, IrDA
300 dpi
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm)
Media Feeders
1 x manual - 1 sheet
1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
Cleaning kit
1 x USB cable
Software Included
Brother P-touch Editor 5
Limited warranty - 1 year
25.5 cm
5.5 cm
3 cm
473 g
Scroll to top
