BT.com
Wishlist
Brother P-Touch PT-P700 Mono Labelling Machine
Brother P-Touch PT-P700 Mono...
£59.80
25 in stock
£59.80
Add to wishlist
Delivery
Standard 3-5 working days
With the PT-P700, clear, professional-looking labelling on files, archives, cupboards, shelves, data backup discs and more couldn't be simpler. Just plug direct into your PC or Mac via USB, and create designs using your existing fonts, images, graphics and frames. Features barcode printing and a wide range of downloadable templates available from the cloud, while labels are available in different colours and up to 24mm width.
And with up to 30mm per second print speed, the PT-P700 won't keep you waiting.
Brother P-Touch PT-P700 - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
710 g
Max Media Size
Roll (2.4 cm)
Print Speed
Up to 30 mm/sec
Max Resolution (B&W)
180 dpi
USB 2.0
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Postnet, PDF417, Data Matrix, ITF, Micro QR code, GS1 DataBar Composites
Media Type
Laminated tape
Compatible Tapes
TZe tape
Character Sizes
72 points
Styles & Effects
Bold, normal, vertical, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround, strikethrough
Auto cutter, 7 line printing
Required 6 x AA type
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x
7.8 cm x 15.2 cm x 14.3 cm
Printer Type
Printer
Print Speed
Up to 30 mm/sec
Built-in Devices
Cutter
USB 2.0
180 dpi
Character Sizes
72 points
Styles & Effects
Barcodes
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (2.4 cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
18.1 mm
Media Feeders
1 x manual - 1 roll - Roll (2.4 cm)
1 x USB 2.0 - 4 pin mini-USB Type B
Media Included
1 24 mm x 4 m black on white TZe laminated tape cassette
AA type
Required Qty
6
Software Included
Brother P-touch Editor V5.1
7.8 cm
15.2 cm
14.3 cm
710 g
Scroll to top
