BT.com
Wishlist
Brother P-Touch 9600 Labelmaker Serial and USB
Delivery
Standard Due date unavailable
The PT-9600 allows you to label in more ways than ever, so it's the ideal machine to have by your side is you want to keep everything perfectly ordered and organised.
Whether you use it with your PC or Mac or as a standalone electronic label printer, the PT-9600 delivers sharp, clear results – even when you're dealing with bar codes and serial numbers – and you can include a wide range of common industry symbols on your labels too.
This hardworking machine also lets you download label designs and transfer images and graphics. The notebook-style portability makes it simple to apply crack and peel labels, while the backlit display also makes previewing and editing easy.
No job's too big or too small for the versatile label printer, which produce high quality, durable labels that always stay put.
Brother P-Touch PT-9600 - labelmaker
Printer Type
Labelmaker
Portable
2.2 kg
Max Media Size
Roll (3.6cm)
Print Speed
Up to 20 mm/sec
Max Resolution (B&W)
360 dpi
USB, serial
Flash Memory Installed (Max)
8 MB
Barcodes
Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5
Media Type
Laminated tape, fabric tape, security tape, design tape, lettering tape
Compatible Tapes
TZ tape
Fonts
Brussels, Florida, Helsinki, US, San Diego, Los Angeles, Istanbul, Brunei Bold, Bermuda Script, Letter Gothic
Character Sizes
Auto, 9 points, 6 points, 36 points, 24 points, 18 points, 12 points, 10 points, 14 points, 20 points, 28 points, 7 points, 11 points, 5 points, 56 points, 72 points, 48 points, 16 points, 8 points, 76 points, 64 points, 40 points, 4 points, 22 points, 32 points
Styles & Effects
Vertical, Mirror, rotated text
16 line printing, auto currency calculation
Display Resolution
3 lines x 20 characters
Keyboard
QWERTY
Total Media Capacity
1 roll
Nickel Metal Hydride
Microsoft Windows 98 Second Edition, Apple MacOS 8.6 or later, Microsoft Windows 98/ME/2000/XP
Enclosure Colour
Dark grey
1 year warranty
23.6 cm x 30.2 cm x 10.4 cm
Printer Type
Labelmaker
Enclosure Colour
Dark grey
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Character keyboard, status LCD, cutter
Wired
USB, serial
360 dpi
Fonts
Character Sizes
Styles & Effects
Display Resolution
Auto Cutter
Keyboard
QWERTY
Repeating Printing
999 copies
Barcodes
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Compatible Tapes
TZ tape
Max Media Size
Roll (3.6cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
1 roll
Media Feeders
1 x manual - 1 roll - Roll (3.6cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
Carrying case
1 x USB cable
Power adapter + battery charger
Software Included
Drivers & Utilities
System Requirements Details
Windows 98/2000/ME/XP - RAM 64 MB - HD 20 MB , Windows 98 SE - RAM 64 MB - HD 20 MB , MacOS 8.6 or later - PowerPC RAM 32 MB - HD 20 MB
Limited warranty - 1 year
23.6 cm
30.2 cm
10.4 cm
2.2 kg
Scroll to top
