BT.com
Wishlist
Brother MFC990CW Colour InkJet AIO
Delivery
Standard Due date unavailable
The MFC-990cw is a feature packed wireless all-in-one printer, copier, scanner and fax. Using the 4.2" color TouchScreen display, it is easy to preview faxes, enhance and edit photos, and view help menus. Photos can also be printed directly from most Bluetooth wireless technology enabled hand held devices. This model includes a digital answering machine with full duplex speakerphone and 5.8GHz digital cordless handset.
Brother MFC-990cw - multifunction printer (colour)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 22 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 33 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
4.2"
Original Size
216 x 356 mm (max)
Original Type
Sheets, books
Document Feeder Capacity
15 sheets
Media Size
89 x 127 mm (min) - 216 x 356 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, photo paper, coated paper
Standard Media Capacity
100 sheets
Output Trays Capacity
50 sheets
PC Connection
USB 2.0, LAN, USB host, Wi-Fi
Office Machine Features
Save to memory card, save to USB flash drive
46.8 cm x 37.5 cm x 18 cm
8.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
4.2"
PC Connection
Standard Memory
48 MB
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, xD-Picture Card, Memory Stick PRO, USB flash drive, SDHC Memory Card
Copying
Max Copying Speed
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, Poster-9, 4 on 1
Printing
Nozzle Configuration
94 nozzles (black), 3 x 94 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Image Enhancement Technology
Brother True2Life
Ink Type
Brother Innobella ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
36 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 960 pages
Reception Memory Capacity
Up to 480 pages
Transmission Memory Capacity
Up to 480 pages
Handset
Cordless handset
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Caller ID
Broadcast Transmission
250 stations
Delayed Transmission
50 stations
Remote Fax Retrieval (Polling)
Fax forwarding, transmit verification report, Distinctive Ring Pattern Detection (DRPD), automatic redialing
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets, books
15 sheets
Min Media Size
89 x 127 mm
Max Media Size
Other
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, 127 x 177.8 mm
100 sheets
50 sheets
ADF - 15 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Input tray - 100 sheets size: 89 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 20 sheets size: 89 x 127 mm - 101.6 x 152.4 mm - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 27 ppm - colour , Copying: up to 22 ppm - B/W , Copying: up to 20 ppm - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP
Security Protocols & Features
LEAP, WEP, WPA-PSK, WPA, WPA2
Operating System Support
Apple MacOS X 10.2.4 or later, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional
Software Included
ScanSoft PaperPort SE 11.0, Presto! PageManager 7
Direct Printing Specifications
PictBridge, DPOF
Phone cable
Limited warranty - 1 year - on-site
46.8 cm
37.5 cm
18 cm
8.6 kg
Shipping Width
55.6 cm
Shipping Depth
25.3 cm
Shipping Height
46 cm
Shipping Weight
12.5 kg
Accessories
£15.86
£8.54
£8.48
£8.48
Scroll to top
