BT.com
Wishlist
Brother MFC8520DN Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
You can rely on the MFC-8520DN, even in the most demanding office circumstances.
This versatile, multifunction machine can handle even the heaviest of workloads thanks to a paper tray that can hold up to 300 sheets. With its high-speed output of up to 36ppm and duplex automatic printing function, it produces professional documents and scans in sharp, crisp detail.  It also boasts an optional 8,000 page toner cartridge and optional 800-sheet paper capacity, as well as cost-saving and energy saving features.
The MFC-8520DN always delivers professional quality, consistently meeting all your business needs.
Brother MFC-8520DN - multifunction printer (B/W)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
3500 pages
Max Copying Speed
Up to 36 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 36 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
69.8 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Google Cloud Print ready
40.5 cm x 41.5 cm x 42.3 cm
16 kg
Microsoft Certification
Compatible with Windows 7
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
3500 pages
Display
5 lines x 22 characters
PC Connection
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
384 MB
Copying
Max Copying Speed
Up to 36 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 36 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, BR-Script 3
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One Touch Dialing
16 station(s)
Speed Dialing
300 station(s)
Broadcast Transmission
366 stations
Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
69.8 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 150 sheets , Bypass tray - 50 sheets size: 76.2 x 127 mm - 216 x 406.4 mm weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 36 ppm - B/W , Copying: up to 36 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
IPv4, IPv6
Security Protocols & Features
SSL
Operating System Support
MS Windows XP, Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, Apple Mac OS X 10.7.x
Software Included
Drivers & Utilities, Brother BR-Admin Professional, Brother BR-Admin Light for Linux & Macintosh
651 Watt
Power Consumption Standby
8.1 Watt
Power Consumption Sleep
1.2 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 2000 pages , 1 x drum (black) - up to 30000 pages - Brother DR3300
Limited warranty - 1 year
40.5 cm
41.5 cm
42.3 cm
16 kg
Shipping Width
53.3 cm
Shipping Depth
51.5 cm
Shipping Height
60.1 cm
Shipping Weight
20.1 kg
Sound Emission
37 dBA (idle) / 59 dBA (operating)
Accessories
Brother DR-3300 Drum Unit
Quicklinx: 8867 | In Stock
£124.63
Brother TN3330 Toner Cartridge - Black
Quicklinx: 88RN | In Stock
£66.25
Brother TN3380 Black Toner Cartridge
Quicklinx: 88RP | In Stock
£105.93
Scroll to top
