BT.com
Wishlist
Brother MFC-L8850CDW Colour Laser Multifunction Printer
Brother MFC-L8850CDW Colour Laser...
£700.16
Hurry, only 1 left in stock!
£700.16
Add to wishlist
Delivery
Standard 1-3 working days
The new MFC-L8850CDW delivers the professional business colour print, copy, scan and fax performance that savvy business customers have come to expect from Brother. It also does it at a best-in-class 30ppm colour & mono print speed and includes a host of features designed for today's demanding work environment.
Not only that, but the MFC-L8850CDW also makes sharing a breeze thanks to full PC, tablet and mobile device connectivity via wireless and Wi-Fi direct. The cloud is just a few clicks away using the clear, easy-to-use 9.3cm touchscreen LCD, while back on earth environmental impact is reduced with high-yield toners and print features that can help reduce paper consumption by up to 75%.
Brother MFC-L8850CDW - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
4.85"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
AC 230 V (50/60Hz)
49 cm x 52.6 cm x 53 cm
31 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Laser - colour
60000 pages
750 - 4000 pages
Display Diagonal Size
4.85"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
Telephone / Fax Switch
Broadcast Transmission
350 stations
Fax forwarding, automatic redialing, auto reduction, Distinctive Ring Detection (DRD), Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2 x64 Edition
AC 230 V (50/60Hz)
565 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
10.5 Watt
First Copy Out Time B/W
18 sec
First Copy Out Time Colour
20 sec
Consumables Included
1 x Cartridge (black) - up to 2500 pages , 1 x Cartridge (cyan) - up to 1500 pages , 1 x Cartridge (magenta) - up to 1500 pages , 1 x Cartridge (yellow) - up to 1500 pages
49 cm
52.6 cm
53 cm
31 kg
Shipping Width
66 cm
Shipping Depth
62.5 cm
Shipping Height
69.8 cm
Shipping Weight
36.8 kg
Sound Emission
28 dBA (idle) / 56 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
