BT.com
Wishlist
Brother MFC-L6800DW A4 Mono Laser Multifunction With Free LT-5505
Delivery
Standard Due date unavailable
For businesses with higher print and scan volumes, the cost-effective and business-durable MFC-L6800DW all-in-one is a great choice. Productivity features on this printer include fast printing and copying and a rapid monochrome scan speed. Plus, it features single-pass, two-sided monochrome scanning at an impressive rate. Additional paper trays enable more flexibility and expandability based on business needs and potential growth. With the addition of a high-yield replacement toner cartridge, business users may enjoy lower cost printing. This model also helps deliver wireless mobile device connectivity including NFC for convenient printing, scanning, and network user authentication.
Printer comes with free LT-5505 Tray!
Brother MFC-L6800DW - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Bundled Services
Brother PRINT AirBag for 750000 pages
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
125000 pages
Recommended Monthly Volume
7500 pages
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 46 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Display
4.85"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
80 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
570 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Google Cloud Print ready, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
49.5 cm x 51.8 cm x 42.7 cm
18.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
3 years warranty
Fax Type
Plain paper
Bundled Services
Printing Technology
Laser - monochrome
125000 pages
7500 pages
Display Diagonal Size
4.85"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 46 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, PDF 1.7, XPS, EPSON FX
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
300 station(s)
Broadcast Transmission
350 stations
Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
80 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
570 sheets
50 sheets
250 sheets
Input tray - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² weight (lbs): , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² weight (lbs): , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² weight (lbs): , Output tray - 250 sheets weight (lbs):
Speed Details
Printing: up to 46 ppm - B/W , Printing: up to 24 spm - B/W duplex , Scanning: up to 50 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
AC 230 V (50/60Hz)
745 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
8 Watt
First Copy Out Time B/W
9.5 sec
Consumables Included
1 x Cartridge (black) - up to 8000 pages , 1 x drum (black) - up to 50000 pages - Brother DR3400
Blue Angel Compliant
Limited warranty - 3 years
49.5 cm
51.8 cm
42.7 cm
18.9 kg
Sound Emission
35 dBA (idle) / 57 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
