BT.com
Wishlist
Brother MFC-L2740DW Mono Laser Printer
Brother MFC-L2740DW Mono Laser...
Cashback
£225.91
Cashback
Purchase with 2 Standard Yield Toner and receive £30 Cashback!
17 in stock
£225.91
Add to wishlist
Delivery
Standard 1-3 working days
The MFC-L2740DW is a fast, professional, network-ready mono laser printer, scanner, copier and fax perfect for the Small or Home Office.
With cloud connectivity, and compatible with a number of mobile printing apps, this professional All-in-One matches the ambitions of even the most technologically savvy Small Office. Also offering Wi-Fi and Wired Network connectivity you can print from anywhere and using a number of devices.
The 6.8cm colour touchscreen makes menu navigation simple, while print speeds of up to 30ppm mean there's no waiting around once you've pressed print. Also expect quick and easy printing and scanning from anywhere using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint or Wi-Fi Direct, as well as scan and print capability to and from cloud services such as Dropbox, evernote and onedrive.
Boasting a 250 sheet paper tray and 35 sheet Automatic Document Feeder look forward to more time between refills and set jobs to print while you carry on with the tasks that matter. As well as saving time, save money with the standard 1200 page inbox toner, with optional cost-effective, high-yield toner cartridges available. Double-sided printing, copying, scanning and faxing also helps to reduce unnecessary waste.
Brother MFC-L2740DW - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
600 x 2400 dpi
Display
2.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to e-mail, AOSS, Google Cloud Print ready
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
250 - 2000 pages
Display Diagonal Size
2.7"
Display Features
Touch screen
PC Connection
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 30 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, BR-Script 3
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
30 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Telephone / Fax Switch
Broadcast Transmission
250 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 15 spm (A4) - B/W duplex , Copying: up to 30 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WPA-PSK, WPA2-PSK, TKIP, AES, ARP
Operating System Support
MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
AC 230 V (50/60Hz)
510 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
1.2 Watt
Warm Up Time
9 sec
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 1200 pages , 1 x drum (black) - up to 12000 pages
IEC 60825-1:2007
Blue Angel Compliant
40.9 cm
39.85 cm
31.65 cm
11.8 kg
Shipping Width
56.7 cm
Shipping Depth
51.7 cm
Shipping Height
43.5 cm
Shipping Weight
14.8 kg
Sound Emission
33 dBA (idle) / 50 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Other bundles
£225.91
Save on TP Link Smart Plug
Save £2.00
£249.88
Scroll to top
