BT.com
Wishlist
Brother MFC-L2700DW A4 Mono Multifunction Laser Printer
Brother MFC-L2700DW A4 Mono...
£110.02
17 in stock
£110.02
Add to wishlist
Delivery
Standard 1-3 working days
Ensuring a high-quality and consistent print performance, the compact Brother MFC-L2700DN delivers reliable, wired network technology to your office, making it ideal for sharing with up to three people.
High-resolution print, copy, scan and fax combine for a professional, sharp output in crisp black and white. With print speeds of up to 24ppm and a 250 sheet paper tray the MFC-L2700DN is the all-in-one mono laser solution to even the most demanding office requirements.
Built with business in mind, this device offers time, waste and money saving features. Automatic 2-sided print not only allows simple A5 booklet printing but can reduce consumption by up to 75%, while optional high-yield toners with a separate drum ensures running costs are kept to a minimum.
The 2 line LCD screen makes accessing features quick, easy and intuitive, and with a first page out time of less than 8.5 seconds you won't be left waiting to pick up your documents when you get to the printer. For further efficiency the 35 sheet automatic document feeder allows multiple scan jobs to complete without the need for manual intervention.
Comprehensive mobile and cloud connectivity options make for seamless integration into your office. Print and scan directly from your mobile device, using either our free Brother
app or using AirPrint, without the need for a PC. Also send and retrieve documents to and from the cloud with a range of compatible apps.
So for complete laser reliability and low running costs, make the MFC-L2700DN choice for your office.
Brother MFC-L2700DN - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
250 - 2000 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
600 x 2400 dpi
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.4 kg
Microsoft Certification
Compatible with Windows 7
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
250 - 2000 pages
Display
2 lines x 16 characters
PC Connection
USB 2.0, LAN
Standard Memory
32 MB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
Windows GDI driver
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
30 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
Fax Machine Features
One Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
258 stations
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 24 ppm (A4) - B/W , Printing: up to 12 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
Linux, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits)
AC 230 V (50/60Hz)
430 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
1.3 Watt
First Copy Out Time B/W
10 sec
Limited warranty - 1 year
40.9 cm
39.85 cm
31.65 cm
11.4 kg
Shipping Width
56.7 cm
Shipping Depth
51.7 cm
Shipping Height
43.5 cm
Shipping Weight
14.4 kg
Sound Emission
33 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
