BT.com
Wishlist
Brother MFC J6710DW Inkjet All-in-One
Delivery
Standard Due date unavailable
Print on a variety of paper sizes with the versatility to print up to 11" x 17". Print two-sided documents up to 11" x 17" in-house. Easy to set up wireless (802.11b/g/n) or Ethernet networking with embedded web server support. Two adjustable paper trays hold up to 500 sheets. Uses high or super high yield ink cartridges.
Brother MFC-J6710DW - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
3.3"
Original Size
148 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, photo paper
Standard Media Capacity
500 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail
AC 230 V ( 50/60Hz )
54 cm x 33.1 cm x 48.9 cm
18.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , Blue Angel
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3.3"
PC Connection
Standard Memory
64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Nozzle Configuration
210 nozzles (black), 3 x 210 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
One Touch Dialing
16 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
266 stations
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
260 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm
Borderless Photo Sizes
500 sheets
50 sheets
Input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets , ADF - 35 sheets - A3 (297 x 420 mm) , Input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 105 g/m² , Bypass tray - 1 sheet weight: 64 g/m² - 260 g/m²
Speed Details
Printing: up to 12 ipm - B/W , Printing: up to 10 ipm - colour , Printing: up to 27 ppm - colour draft , Printing: up to 35 ppm - B/W draft , Copying: up to 23 ppm - colour , Copying: up to 20 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, MS Windows 2000 Professional, Apple Mac OS X 10.5.x
Software Included
ScanSoft PaperPort SE, Brother Control Centre, Brother MFL-Pro Suite, Presto! PageManager 7, Reallusion FaceFilter Studio, ScanSoft PaperPort SE 12.0
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
Blue Angel Compliant
Limited warranty - 1 year
54 cm
33.1 cm
48.9 cm
18.2 kg
Shipping Width
65.6 cm
Shipping Depth
59.7 cm
Shipping Height
44 cm
Shipping Weight
25 kg
Sound Emission
50 dB (operating)
10 °C
35 °C
20 - 80%
Accessories
£16.17
£10.34
£10.34
£10.34
£23.30
£14.24
£14.24
£14.24
Brother LC1280 Inkjet Cartridge Value Pack
Quicklinx: 8MW7 | In Stock
£65.14
£46.83
Scroll to top
