Click to visit BT.com
BT.com
Wishlist
Brother MFC-J6510DW Wireless Ready Inkjet All-in-One
5.0*
Quicklinx: 7CK3WS00
Mfr#: MFCJ6510DWZU1
Essential accessories
Wireless Ready All in One A3 Inkjet Printer
An all-round professional - that's the MFC-J6510DW! Its biggest feature is the affordable A3 printing, copying, scanning and faxing, alongside the handy A3 double-sided printing feature - ideal if you want to save paper or even create your own A4 brochures in-house! It's fast with 12/10 images per minute mono/colour print speed, plus with the XL ink cartridge option lasting up to an incredible 2400 pages, you'll save on running costs. It's also great for sharing, thanks to the enhanced connectivity of wireless N technology.
Brother MFC-J6510DW - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, cards, photo paper
Standard Media Capacity
250 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
54 cm x 48.9 cm x 25.7 cm
15.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , Blue Angel
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
PC Connection
Standard Memory
64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 400 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
Remote Fax Retrieval (Polling)
Yes (black only)
Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 102 x 152 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm, 89 x 127 mm
250 sheets
50 sheets
Input tray - 250 sheets , Output tray - 50 sheets , ADF - 35 sheets
Speed Details
Printing : up to 35 ppm - B/W draft , Printing : up to 27 ppm - colour draft , Copying : up to 23 ppm - colour , Copying : up to 20 ppm - B/W , Printing : up to 12 ipm - B/W (ISO/IEC 24734) , Printing : up to 10 ipm - color (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WPA-PSK, WPA2-PSK
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, Apple Mac OS X 10.5.x
Software Included
Reallusion FaceFilter Studio
26 Watt
Power Consumption Standby
7.5 Watt
Power Consumption Sleep
0.3 Watt
Direct Printing Specifications
PictBridge
Phone cable
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
Blue Angel Compliant
Limited warranty - 1 year
54 cm
48.9 cm
25.7 cm
15.8 kg
Shipping Width
65.6 cm
Shipping Depth
59.7 cm
Shipping Height
37.8 cm
Shipping Weight
22.4 kg
Sound Emission
50 dBA (operating)
7CK3 Brother LC1240BK - Print cartridge - 1 x black - 600 pages In Stock £16.36
7CK3 Brother LC1240C - Print cartridge - 1 x cyan - 600 pages In Stock £10.47
7CK3 Brother LC1240M - Print cartridge - 1 x magenta - 600 pages In Stock £10.32
7CK3 Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages In Stock £10.47
7CK3 Brother LC1280XLBK - Print cartridge - 1 x black - 2400 pages In Stock £23.56
7CK3 Brother LC1280XLC - Print cartridge - 1 x cyan - 1200 pages In Stock £14.18
7CK3 Brother LC1280XLM - Print cartridge - 1 x magenta - 1200 pages In Stock £14.18
7CK3 Brother LC1280XLY - Print cartridge - 1 x yellow - 1200 pages In Stock £14.18
Customer reviews
Write a review for the Brother MFC-J6510DW Wireless Ready Inkjet All-in-One here!
have not purchase yet
Reviewed by BILLIE. Review Posted 15/02/2012
no review
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Brother MFC-J6510DW printer
Reviewed by GP. Review Posted 28/10/2012
I have been looking for an A3 printer for a while now, mainly for genealogy printouts. I had a look at the Brother web site and found this product still current but at over £300 I ruled it out on cost. So when I received the BT EMail with this printer at half price I looked again. With all the extra features(Fax, A3scan, A3copy, etc) that came with the machine as a bonus to me. I jumped at it and bought one. The WiFi is easy to set up if you follow the instructions. It is a large machine so measure your location first [if you intend to keep the paper tray loaded with A3 paper add a further 6 inches or so to the front to back dim.] The build quality is good,the paper tray is a bit flimsy but no more so than many other printers. The front loading man sized ink cartridges are V.easy to replace, how long they last? I have no idea yet. The main software that is supplied "FL Pro" is only licenced for 2 users, Which for a network printer seems a bit strange, but all in all a nice printer.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
