Click to visit BT.com
BT.com
Wishlist
Brother MFC-J5910DW Colour Inkjet Multifunction Printer
Quicklinx: 7X14WS00
Mfr#: MFCJ5910DWZU1
Essential accessories
All-in-one A3 colour printing just got faster and more affordable. Quickly print, copy, scan or fax using the MFC-J5910DW, a model that's compact enough for any office, whether it's at home or at work.
With precision colour printing up to A3, your presentations, projects and photographs can be given more punch than previously possible, whilst our XL cartridges help you considerably reduce running costs. Plus, the latest wireless 'N' technology means you can share the benefits of the small printer with big capability with the rest of the team in your office -or the family at home.
Print, copy, scan, fax with this feature-packed professional series inkjet all-in-one. Make an impression for less with the MFC-J5910dw. Conveniently print 11" x 17" documents while keeping your cost down with super high yield replacement ink cartridges. This powerful business inkjet All-in-One offers built-in auto duplex (two-sided) printing up to 11" x 17" and built-in wireless 802.11b/g/n and Ethernet networking. 1.9" touchscreen color LCD display plus Touch Panel provides easy menu navigation.
Get 12 months free subscription to Trend Micro™ Titanium™ Antivirus+ 2012 with every purchase of a Brother promotional all-in-one printer!
Click here to claim - http://www.brother.eu/g3.cfm/s_page/508380
Brother MFC-J5910DW - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
1.9"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A3 (297 x 420 mm) (max)
Media Type
Transparencies, envelopes, plain paper, photo paper
Standard Media Capacity
250 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from memory card, save to memory card, save to USB flash drive, scan to e-mail, AOSS
AC 230 V ( 50/60Hz )
51.4 cm x 46.1 cm x 26 cm
13.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , Blue Angel
2 years warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.9"
Display Features
Touch screen
PC Connection
Standard Memory
64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
Max Copying Speed
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, Poster-9, 4 on 1
Printing
Nozzle Configuration
210 nozzles (black), 3 x 210 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
200 stations
Remote Fax Retrieval (Polling)
Yes (black only)
Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
250 sheets
50 sheets
Input tray - 250 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , ADF - 35 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets
Speed Details
Printing : up to 35 ppm - B/W , Printing : up to 27 ppm - colour , Copying : up to 23 ppm - B/W , Copying : up to 20 ppm - colour , Printing : up to 12 ipm - B/W (ISO/IEC 24734) , Printing : up to 10 ipm - color (ISO/IEC 24734) , Copying : up to 6 ipm - B/W (ISO/IEC 24734) , Copying : up to 6 ipm - color (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, IPv4
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS
Operating System Support
MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
Brother ControlCentre2, Brother MFL-Pro Suite, Reallusion FaceFilter Studio, Presto! PageManager 7 for Mac, ScanSoft PaperPort SE 12.0, Brother ControlCenter4
21 Watt
Power Consumption Standby
6 Watt
Power Consumption Sleep
3.5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
Blue Angel Compliant
51.4 cm
46.1 cm
26 cm
13.6 kg
Shipping Width
62.5 cm
Shipping Depth
56.5 cm
Shipping Height
37 cm
Shipping Weight
18.7 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
7X14 Brother LC1240BK - Print cartridge - 1 x black - 600 pages In Stock £16.36
7X14 Brother LC1240C - Print cartridge - 1 x cyan - 600 pages In Stock £10.47
7X14 Brother LC1240M - Print cartridge - 1 x magenta - 600 pages In Stock £10.32
7X14 Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages In Stock £10.47
7X14 Brother LC1280XLBK - Print cartridge - 1 x black - 2400 pages In Stock £23.56
7X14 Brother LC1280XLC - Print cartridge - 1 x cyan - 1200 pages In Stock £14.18
7X14 Brother LC1280XLM - Print cartridge - 1 x magenta - 1200 pages In Stock £14.18
7X14 Brother LC1280XLY - Print cartridge - 1 x yellow - 1200 pages In Stock £14.18
7X14 Brother LC1280 Inkjet Cartridge Value Pack In Stock £65.90
7X14 Brother LC1240 Black/Cyan/Magenta/Yellow Value Pack In Stock £47.40
