BT.com
Wishlist
Brother MFC J4610DW Colour Inkjet Multifunction Printer
Delivery
Standard Due date unavailable
Wireless Colour Inkjet All-in-One with Duplex and Fax
The MFC-J4610DW is part of the Business Smart Series- A line of color inkjet all-in-ones that delivers the ultimate combination of fast print speeds, easy-to-use features, low cost printing and up to 11" x 17" printing in a compact design. This wireless all-in-one has a 1.8" TouchScreen Display plus TouchPanel that only shows you the keys you need, a print technology that allows you to store and feed paper in landscape orientation and dual paper trays for high volume printing. Nobody said you can't have it all!
Key Benefits
Save time with high speed 20/ 18ipm mono/ colour printing
Flexible paper handling with 400 sheet paper capacity, 20 sheet ADF and an A3 Bypass tray
AirPrintTM and Google Cloud PrintTM ready
Improve your workflow with advanced scan and fax features
Intuitive 4.5cm touch screen LCD enables quick access to cloud services including Google Docs, Facebook, Flickr, Picassa, Dropbox and Evernote
Faster and more secure 802.11n wireless connection or connect to your network via the built-in Ethernet, or to your PC with Hi-Speed USB 2.0
Lower operational costs with optional high yield supplies and automatic 2-sided printing
Brother MFC-J4610DW - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
1.8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, photo paper, coated paper
Standard Media Capacity
400 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, AOSS, Google Cloud Print ready
AC 230 V (50/60Hz)
48 cm x 29 cm x 25.4 cm
10.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.8"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Broadcast Transmission
200 stations
Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm
400 sheets
1 sheet
50 sheets
Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , ADF - 20 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 35 ppm - B/W fast , Printing: up to 27 ppm - colour fast , Printing: up to 20 ipm - B/W (ISO/IEC 24734) , Printing: up to 18 ipm - color (ISO/IEC 24734) , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, Windows 8
AC 230 V (50/60Hz)
21 Watt
Power Consumption Standby
6 Watt
Power Consumption Sleep
1.5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
Blue Angel Compliant
Limited warranty - 1 year
48 cm
29 cm
25.4 cm
10.8 kg
Shipping Width
56.4 cm
Shipping Depth
32.9 cm
Shipping Height
41.6 cm
Shipping Weight
13 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
Accessories
Brother LC123BK Black Ink Cartridge
Quicklinx: 8NGY | In Stock
£17.41
Brother LC123C Cyan Ink Cartridge
Quicklinx: 8NGZ | In Stock
£11.14
Brother LC123M Magenta Ink Cartridge
Quicklinx: 8NH0 | In Stock
£11.14
Brother LC123Y Yellow Ink Cartridge
Quicklinx: 8NH1 | In Stock
£11.14
Brother LC125XLC Cyan Ink Cartridge
Quicklinx: 8NH3 | In Stock
£15.32
Brother LC125XLM Magenta Ink Cartridge
Quicklinx: 8NH4 | In Stock
£15.32
Brother LC125XLY Yellow Ink Cartridge
Quicklinx: 8NH6 | In Stock
£15.32
Brother LC127XLBK Black Ink Cartridge
Quicklinx: 8NH7 | In Stock
£23.35
Scroll to top
