BT.com
Wishlist
Brother MFC 9320CW Colour Laser All-in-One
Delivery
Standard Due date unavailable
The MFC-9320CW is a compact and affordable digital color all-in-one solution which combines printing, copying, scanning and faxing into one powerful space-saving device. Delivering brilliant color output, you can produce impact presentations, flyers, brochures and other critical business documents. It offers flexible connectivity with Ethernet and wireless interfaces so it can be installed on a wired or wireless network for multiple users to share printing, scanning and PC faxing. Enjoy the convenience of stand-alone copying and copy reduction or enlargement from 25-400%. With faxing, you have the flexibility of stand-alone faxing or sending faxes from your PC. It also has a USB Direct Interface to print from or scan to your USB flash memory drive or print from your PictBridge-enabled camera, too!
Brother MFC-9320CW - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED ( colour )
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
1200 x 2400 dpi
Original Size
147 x 147 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 116 mm (min) - 220 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host, Wi-Fi
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail
42.8 cm x 49.1 cm x 40.1 cm
22.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - colour
Display
2 lines x 16 characters
PC Connection
Standard Memory
64 MB
Max Supported Memory
576 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 600 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Caller ID
Broadcast Transmission
258 stations
Automatic redialing
Document & Media Handling
Min Original Size
147 x 147 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Supported Media Type
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 35 sheets size: 147 x 147 mm - Legal (216 x 356 mm) , Bypass tray - 1 sheet size: 76.2 x 116 mm - 220 x 406.4 mm
Speed Details
Copying: up to 16 ppm - B/W , Copying: up to 16 ppm - colour , Printing: up to 16 ppm - B/W , Printing: up to 16 ppm - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, AppleTalk, IPP, LPR/LPD
Security Protocols & Features
SSL, TLS
480 Watt
Power Consumption Standby
75 Watt
Power Consumption Sleep
12 Watt
Direct Printing Specifications
PictBridge
Limited warranty - 1 year - on-site
42.8 cm
49.1 cm
40.1 cm
22.9 kg
Shipping Width
62.7 cm
Shipping Depth
65.3 cm
Shipping Height
57.5 cm
Shipping Weight
29 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
Accessories
Brother HL3000 Black 2.2k Toner
Quicklinx: 6MPZ | In Stock
£57.01
£55.09
£55.09
£55.09
Brother DR230CL DRUM
Quicklinx: 7ZH7 | In Stock
£86.00
Scroll to top
