BT.com
Wishlist
Brother HLL6400 Mono Laser Printer
£508.29
14 in stock
£508.29
Add to wishlist
Delivery
Standard 1-3 working days
Open up new business opportunities with this robust machine. Offering excellent paper handling options, super fast print speeds and the new optional ultra-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your business.
Key Features
  • Super-fast print speeds of up to 50ppm.
  • Outstanding paper handling options with a standard paper capacity of 570 sheets expandable to 2,650 sheets.
  • 12,000 page inbox toner & optional ultra high yield 20,000 page toner cartridge.
  • Intuitive 4.5cm touchscreen LCD display.
  • Integrated NFC Reader, giving users better document security and improved user authentication for pull printing.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays, and mailbox options across the range. This provides maximum device uptime, as less time is spent replenishing paper trays and searching for your printed documents. With the optional ultra high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Brother HL-L6400DW - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
Media Size Class
A4/Legal
Min Media Size (Custom)
127 mm
Automatic Duplexing
Printer Type
Printer
Wired
Automatic Duplexing
Media Handling
Media Size Class
A4/Legal
127 mm
Power supply
Environmental Standards
Blue Angel
Scroll to top
