BT.com
Wishlist
Brother HL3140CW Colour Laser Printer
Brother HL3140CW Colour Laser...
£114.16
Compact, reliable and specially designed to suit smaller office spaces
More than 50 in stock
£114.16
Add to wishlist
Delivery
Standard 1-3 working days
Brother HL-3140CW Compact Colour Laser Printer With Wi-fi
At last, a compact, high quality colour printer that is affordable to buy and affordable to run too. This is an exciting development for many small to medium sized businesses who want the impact of using colour.
This entry level printer is part of Brother's next generation colour LED printers, designed for high performance and better value. It's fast, printing 18 pages per minute, easy to use, and built for reliability, giving you the peace of mind that it won't let you down. It offers advanced and flexible connections, whether you need to print direct from USB, or web-based applications such as Apple AirPrint or Google Cloud Print.
  • Save time with fast 18ppm mono/colour printing
  • Flexible paper handling with 250 sheet paper capacity and single sheet bypass tray
  • Faster and more secure 802.11n wireless connection or connect to your PC via high speed USB 2.0
  • Effortless mobile connectivity enables printing direct from your Apple iOS, Android, Windows Phone or Blackberry device
  • Lower operational costs with optional high yield colour supplies
  • Print professional colour documents with output of up to 2,400 x 600dpi resolution
Compact, reliable and specially designed to suit the smaller office space. Create professional-looking colour documents and print directly from your mobile device for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
Key Features
  • Print only
  • Up to 18ppm mono and colour print speed
  • Up to 2,400 x 600dpi print resolution
  • Wireless network ready
  • Print from your mobile device
  • PIN and password protected secure print
  • Compact, reliable and specially designed to suit smaller office spaces
  • Create professional-looking colour documents and print directly from your mobile device to the HL-3140CW for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
  • Like all of our colour LED printers, it incorporates separate toners and drums, reducing waste and saving you money. This flexible printer also offers high-yield colour toner cartridges to keep costs down without compromising on quality.
  • And with print speeds of up to 18ppm, the HL-3140CW won't keep you waiting for your documents.
AirPrint
Compatible with AirPrint by Apple.
Mobile Compatible
Mobile device compatible. Connect with your smartphone or tablet.
WiFi Compatible
Wireless compatible.
Brother HL-3140cw - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
17.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W , Up to 18 ppm - colour
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
USB 2.0, Wi-Fi(n)
333 MHz
RAM Installed (Max)
64 MB
Language Simulation
Windows GDI driver
Media Type
Plain paper, glossy paper, bond paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
300 - 1500 pages
Print server
Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1 year warranty
41 cm x 46.5 cm x 24 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
USB 2.0, Wi-Fi(n)
2400 x 600 dpi
2400 x 600 dpi
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Windows GDI driver
Media Handling
333 MHz
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
30000 pages
300 - 1500 pages
Print server
Security Protocols & Features
Kerberos, SSL, WPA-PSK, TLS, 802.1x, WPA2-PSK, ARP
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge ( black ) - up to 1000 pages , 1 x toner cartridge ( cyan ) - up to 1000 pages , 1 x toner cartridge ( magenta ) - up to 1000 pages , 1 x toner cartridge ( yellow ) - up to 1000 pages , 1 x drum
Power supply - internal
335 Watt
Power Consumption Stand by / Sleep
60 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Ecolabel
Limited warranty - 1 year
Sound Emission (Idle)
33 dBA
Sound Emission (Operating)
53 dBA
41 cm
46.5 cm
24 cm
17.4 kg
Width (Shipping)
59.7 cm
Depth (Shipping)
52.1 cm
Height (Shipping)
36.4 cm
Weight (Shipping)
21 kg
Accessories
Brother TN241BK Toner Cartridge Black
Quicklinx: 8NGB | In Stock
£53.35
Brother TN245C Toner Cartridge Cyan
Quicklinx: 8NGH | In Stock
£76.52
Brother Drum Unit yield 15k
Quicklinx: 8R36 | In Stock
£82.10
Scroll to top
