BT.com
Wishlist
Brother HL-L9200CDWT Colour Laser Multifunction Printer
Brother HL-L9200CDWT Colour Laser...
£601.06
Hurry, only 1 left in stock!
£601.06
Add to wishlist
Delivery
Standard 1-3 working days
The HL-L9200CDWT is ideal for the bigger, more demanding office. It offers impressive connectivity - with wired and wireless networking, direct USB connection, and support for the full suite of Brother apps allowing printing and sharing from smartphones and tablets. You can also connect directly to the cloud.
It's efficient and economical too, with print speeds up to a fantastic 30ppm, plus two-sided printing and super-high-yield toners - delivering even higher levels of value and productivity. In fact, the HL-L9200CDWT offers our best ever total cost of ownership for a printer in its class. And despite its advanced features, it's easy to use and manage. Meaning everybody can get first class, professional quality colour prints, first time, every time.
Brother HL-L9200CDWT - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
28.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 32 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 32 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
RAM Installed (Max)
128 MB ( 384 MB ) - DDR2 SDRAM - SO-DIMM 144-pin
Language Simulation
PCL 6, XPS, BR-Script3, PDF 1.7
Media Type
Envelopes, labels, plain paper, glossy paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
800 sheets
Media Handling
250-sheet input tray, 500-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1000 - 5000 pages
Print server
Printer Features
AirStation OneTouch Secure System (AOSS)
AC 230V
Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows XP 32-bit, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple MacOS X 10.9, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 32-bit Edition
41 cm x 49.5 cm x 44.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Touch screen
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Language Simulation
Printer Features
Media Handling
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 163 g/m²
800 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
75000 pages
1000 - 5000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge ( black ) - up to 6000 pages , 1 x toner cartridge ( cyan ) - up to 6000 pages , 1 x toner cartridge ( magenta ) - up to 6000 pages , 1 x toner cartridge ( yellow ) - up to 6000 pages
Google Cloud Print
AC 230V
Frequency Required
50/60 Hz
540 Watt
Power Consumption Stand by
65 Watt
Software Included
Drivers & Utilities
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
27.3 dBA
Sound Emission (Operating)
55.1 dBA
Sound Emission (Quiet Mode)
50.8 dBA
41 cm
49.5 cm
44.5 cm
28.3 kg
Width (Shipping)
81 cm
Depth (Shipping)
59.7 cm
Height (Shipping)
88.7 cm
Weight (Shipping)
39.5 kg
Scroll to top
