BT.com
Wishlist
Brother HL-2130 Mono Laser Printer
Delivery
Standard Due date unavailable
Small office? You've just found your perfect printer. The HL-2130 may be small in size but it's big on efficiency with a fast 20 pages per minute print speed (the first in less than 10 seconds) to make sure you're not kept waiting. The impressive 250-sheet paper capacity saves you time too, with less need for refilling. It keeps costs down with separate drum and toner, Energy Star approved technology and also includes 12 month warranty with lifetime technical support.
You'll appreciate being able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the HL-2130's high print resolution for outstanding results.
With the HL-2130 high performance doesn't mean high costs. Save paper and use less toner by reducing 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-in-1 printing. Using the toner save mode can further reduce your running costs.
Brother HL-2130 - printer - monochrome - laser
Printer Type
Personal printer - laser - monochrome
6.7 kg
Media Size Class
A4
Max Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
69.9 mm x 116 mm
Max Media Size (Custom)
215.9 mm x 406.4 mm
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
USB
200 MHz
RAM Installed (Max)
8 MB
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper, thin paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Apple MacOS X 10.6.x
1 year warranty
36.8 cm x 36 cm x 18.3 cm
Printer Type
Printer
Wired
USB
2400 x 600 dpi
Brother HQ1200
First Print Out Time B/W
10 sec
Media Handling
200 MHz
RAM
RAM Installed (Max)
8 MB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
69.9 mm x 116 mm
215.9 mm x 406.4 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 220 x 406.4 mm weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x drum - up to 12000 pages - Brother DR-2200
421 Watt
Power Consumption Stand by / Sleep
62 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Idle)
31 dBA
Sound Emission (Operating)
53 dBA
36.8 cm
36 cm
18.3 cm
6.7 kg
Accessories
Brother BRO DR2200 DRUM HL2240/2240D/
Quicklinx: 79P7 | In Stock
£61.75
£30.28
Scroll to top
