BT.com
Wishlist
Brother FAX-2940 High Speed Mono Laser Multifunction Printer
Brother FAX-2940 High Speed Mono...
£246.48
£246.48
Add to wishlist
Delivery
Standard 1-3 working days
With a free printer and scanner download available, you can turn the high speed FAX-2940 into a multifunction machine you can depend on.
Easy to set up and operate, it boasts a host of features and technology to help you work smarter. The 250-sheet lower paper tray adds up to less time wasted refilling, while the huge 500-page memory means that, even if your paper does run out, your vital information won't be lost.
The high-yield toner can handle the unit's fast printing speeds – up to 20ppm – while the separate drum keeps running costs low.
All in all a flexible solution offering everything your office needs to operate more efficiently.
Brother FAX-2940 - multifunction printer ( B/W )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( monochrome )
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Type
Plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB
36.8 cm x 36 cm x 31.1 cm
9 kg
Microsoft Certification
Compatible with Windows 7
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
PC Connection
USB
Copying
Max Copying Speed
Up to 20 ppm
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Image Enhancement Technology
Brother HQ1200
First Print Out Time B/W
10 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Reception Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
One Touch Dialing
22 station(s)
Speed Dialing
200 station(s)
Document & Media Handling
Original Type
Sheets
30 sheets
Supported Media Type
Plain paper
250 sheets
100 sheets
ADF - 30 sheets , Input tray - 250 sheets , Output tray - 100 sheets
Speed Details
Copying: up to 20 ppm - B/W , Printing: up to 20 ppm - B/W
1 x USB
360 Watt
Power Consumption Standby
53 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
1 x Cartridge ( black ) - up to 1000 pages , 1 x drum - up to 12000 pages - Brother DR-2200
Limited warranty - 1 year
36.8 cm
36 cm
31.1 cm
9 kg
Shipping Width
47.6 cm
Shipping Depth
45.8 cm
Shipping Height
43.6 cm
Shipping Weight
12.9 kg
Accessories
£52.75
Brother BRO DR2200 DRUM HL2240/2240D/
Quicklinx: 79P7 | In Stock
£59.88
£34.11
Scroll to top
