BT.com
Wishlist
Brother DS820W MOBILE SCANNER
£147.34
£147.34
Add to wishlist
Delivery
Standard 1-3 working days
We do so much via mobile device these days that it's good to know there's a 600dpi scanner that's specifically designed to complement smartphones and tablets.
The rechargeable DS-820W syncs whatever you scan to your chosen mobile device and also offers a 4GB SD card and built-in wireless connectivity. Compatible with Windows and Mac, the DS-820W's professional software bundle also helps you manage and manipulate all the scanned data in a whole host of ways.
In short, this flexible and truly portable scanner enables you to work the way that suits you best.
or
here.
Brother DSmobile 820W - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB 2.0, Wi-Fi(n)
Scan Element Type
Contact Image Sensor (CIS)
Additional Functions
Email, scan to network share, scan to server, scan to flash card
Max Supported Document Size
215.9 x 812.8 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 24-bit (16.7 million colours)
Grayscale / Color Depth (External)
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Size
215.9 mm x 812.8 mm
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Manual
1 x Lithium Ion
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x, Apple MacOS X 10.8.x
30.8 cm x 5.25 cm x 4.07 cm
440 g
1 year warranty
Interface Type
USB 2.0, Wi-Fi(n)
215.9 x 812.8 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Grayscale Depth (External)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Element Type
Scanner Speed Details
7.5 ppm - black & white - A4 - 300 dpi , 8 ppm - black & white - Letter - 300 dpi , 4.3 ppm - black & white - Letter - 400 dpi , 4 ppm - black & white - A4 - 400 dpi , 8 ppm - colour - Letter - 300 dpi , 7.5 ppm - colour - A4 - 300 dpi , 4.3 ppm - colour - Letter - 400 dpi , 4 ppm - colour - A4 - 400 dpi
Scanner Features
Powered by USB port, built-in LCD screen
TWAIN
Media Handling
Max Document Size
215.9 mm x 812.8 mm
Manual
Supported Flash Memory Cards
SD Memory Card
USB 2.0 - Type B
Carrying case, cleaning cloth, calibration paper, 4 GB SD Memory Card, carrier sheet
1 x micro-USB cable
Battery Installed
1 x Lithium Ion
Run Time (Up To)
450 pages
Software Included
Drivers & Utilities, Presto! BizCard 6, Nuance PaperPort 12 SE, Avision Button Manager 2, Presto! PageManager 9 for Mac, DSmobileCapture
30.8 cm
5.25 cm
4.07 cm
440 g
Limited warranty - 1 year
5 °C
35 °C
15 - 85%
Sound Emission
50 dBA
Scroll to top
