BT.com
Wishlist
Brother DS-920DW Mobile Scanner
£170.88
£170.88
Add to wishlist
Delivery
Standard 1-3 working days
The DS-920DW for anywhere, anytime, portable scanning
The DS-920DW includes powerful software for improved workflow, helping you to access and retrieve documents whilst away from the office. Share documents to improve communication and collaboration, cutting down paperwork for office mobility.
Built-in wireless connectivity allows you to wirelessly transfer scanned data to mobile devices, or computers, offering ultimate flexibility while out of the office, while being battery or USB powered offers versatile power options -perfect for varied portable scanning requirements.
An impressive portable 2-sided scan speed of up to 10ipm makes for fast and efficient completion of even challenging workloads. And with 1200 x 1200 dpi interpolated optical image scanning the DS-920DW delivers high-quality digitised documents without a delay.
Added storage options begin with a 4GB SD card included, with the capacity to extend this to 32GB.
With a professional software suite included you can archive, edit and email scanned material using the latest document digitisation software, with the least of effort.
Brother DSmobile 920DW - sheetfed scanner - portable - USB 2.0, Wi-Fi(n)
Sheetfed scanner - portable
Interface Type
USB 2.0, Wi-Fi(n)
Scan Element Type
Dual CIS
Additional Functions
Email, scan to network share, scan to server, scan to flash card, scan to cloud, scan to FTP
Max Supported Document Size
215.9 x 812.8 mm
Input Type
Grayscale / Color Depth
16-bit (64k colours) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 colours) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Size
215.9 mm x 812.8 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card
Document Feeder Type
Manual
Duty Cycle
100 scans per day
1 x Lithium Ion
Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.8.x
30.8 cm x 6.69 cm x 4.12 cm
530 g
Interface Type
USB 2.0, Wi-Fi(n)
215.9 x 812.8 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
8-bit (256 colours)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CIS
Duty Cycle
100 scans per day
Scanner Speed Details
7.5 ppm - black & white - A4 - 300 dpi , 7.5 ppm - colour - A4 - 300 dpi , 5 ppm - duplex - black & white - A4 - 300 dpi , 5 ppm - duplex - colour - A4 - 300 dpi
TWAIN
Media Handling
Max Document Size
215.9 mm x 812.8 mm
Manual
Supported Flash Memory Cards
SD Memory Card
USB 2.0 - Type B
Carrying case, calibration card, cleaning cloth, 4 GB SD Memory Card, carrier sheet
1 x USB cable
Battery Installed
1 x Lithium Ion
Recharge Time
4 hours
Software Included
Drivers & Utilities, Presto! BizCard 6, Nuance PaperPort 12 SE, Avision Button Manager 2, Presto! PageManager 9 for Mac, DSmobileCapture
30.8 cm
6.69 cm
4.12 cm
530 g
Sound Emission
50 dBA
Scroll to top
