BT.com
Wishlist
Brother DCPL6600DW All-In-One Mono Laser Printer
Brother DCPL6600DW All-In-One Mono...
Free Bundle
£548.64
Free Bundle
Free bundled LT-5505 Paper Tray!
34 in stock
£548.64
Add to wishlist
Delivery
Standard 1-3 working days
The all-in-one that’s designed with the busy office in mind. Robust build quality combined with versatile paper handling options gives you outstanding results repeatedly. The new optional super-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your office.
Key Features
  • Super-fast print speeds of up to 46ppm.
  • Super-fast 2-sided scan speeds of up to 100ipm.
  • Outstanding paper handling options with a standard paper capacity of 570 expandable to 2,650.
  • 8,000 page inbox toner & optional ultra high yield 12,000 page toner cartridge.
  • Intuitive 12.3cm touchscreen LCD display.
  • Integrated NFC Reader, giving users better document security and improved user authentication for pull printing.
Maximise Performance & Reduce Print Spend
First page out time is just 7.5 seconds followed by a fast print speed of up to 46ppm. Standard paper input is 570 expandable to 2,650. As well as improved performance, reducing print spend is something that every business looks at - with the optional 12,000 page super high yield toner your overall printing costs will reduce dramatically.
Better Reliability
Perform for longer, with a recommended monthly volume of up to 7,500 pages to meet the demands of the busy office. Plus, units have been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
Design improvements include an 80 page auto document feeder that enables high speed 2-sided scanning straight into a document management system. Along with a more intuitive 12.3cm touchscreen and user-friendly interface and improved support for different media and connectors to popular cloud based services such as Microsoft SharePoint , it’s just what busy workgroups have been waiting for.
Tighter Security
The DCP-L6600DW has the highest levels of security. Meeting requirements with secure function lock 3.0, Active directory connectivity and Internet Protocol Security (IPsec). Plus, the range features Print Archive, Secure Reset.
Flexible print solutions from Brother
Brother print solutions are exciting packages of innovation designed to make doing business easier. By offering a range of print solutions to help your customers maximise print efficiency and minimise costs, we help you add value to every printer.
Eco-friendly
The DCP-L6600DW 3-in-1 is awarded with the stringent German Blue Angel, Nordic Swan and Energy Star environmental standards. That means that this printer is classed as particularly energy efficient. Also, separate toner and drum mean you can help protect the environment and lower costs at the same time.
Brother DCP-L6600DW - multifunction printer (B/W)
Printer / copier / scanner
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 46 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 46 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
1200 x 1200 dpi
Display
4.85"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
80 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
570 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Google Cloud Print ready, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
49.5 cm x 51.8 cm x 42.7 cm
18.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - monochrome
Display Diagonal Size
4.85"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 46 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 46 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, BR-Script 3, PDF 1.7, XPS, EPSON FX
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
Original Type
Sheets
80 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
570 sheets
50 sheets
250 sheets
Input tray - 520 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² weight (lbs): , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² weight (lbs): , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² weight (lbs): , Output tray - 250 sheets weight (lbs):
Speed Details
Printing: up to 46 ppm - B/W , Printing: up to 24 spm - B/W duplex , Scanning: up to 50 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex , Copying: up to 46 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
AC 230 V (50/60Hz)
745 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
8 Watt
First Copy Out Time B/W
9.5 sec
Nordic Swan
Blue Angel Compliant
49.5 cm
51.8 cm
42.7 cm
18.5 kg
Shipping Width
59.9 cm
Shipping Depth
52.6 cm
Shipping Height
65.9 cm
Shipping Weight
22.3 kg
Sound Emission
35 dBA (idle) / 57 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
