BT.com
Wishlist
Brother DCPL5500DN All-In-One Mono Laser Printer
Brother DCPL5500DN All-In-One Mono...
Cashback
£216.01
Cashback
£100 Cashback or 3 Year Warranty Available!
More than 50 in stock
£216.01
Add to wishlist
Delivery
Standard 1-3 working days
Print, scan and copy more efficiently with the DCP-L5500DN. Fast print and scan speeds alongside versatile paper handling options gives you greater efficiency and outstanding results every time. A user friendly 9.3cm touchscreen helps to make this machine the ideal print partner for your office.
Key Features
  • Super-fast print speeds of up to 40ppm and scan speeds of up to 24ipm.
  • Combined paper input of 300 sheets.
  • Automatic 2-sided printing.
  • High-Yield Replacement Cartridges - Optional high yield 8,000 page toner cartridge.
  • Intuitive 9.3cm touchscreen LCD display.
  • High speed wired (10Base-T/100 Base-TX) interface and USB 2.0 connectivity.
Maximise Performance & Reduce Print Spend
First page out time is just 7.5 seconds followed by a fast print speed of up to 40ppm. Standard paper input is 570 expandable to 1,610. As well as improved performance, reducing print spend is something that every business looks at - with the optional 12,000 page super high yield toner your overall printing costs will reduce dramatically.
Better Reliability
Perform for longer, with a recommended monthly volume of up to 5,000 pages to meet the demands of the busy office. Plus, units have been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
Design improvements include an 40 page auto document feeder that enables high speed 2-sided scanning straight into a document management system. Along with a more intuitive 9.3cm touchscreen and user-friendly interface and improved support for different media and connectors to popular cloud based services such as Microsoft SharePoint , it’s just what busy workgroups have been waiting for.
Tighter Security
The DCP-L5500DN has the highest levels of security. Meeting requirements with secure function lock 3.0, Active directory connectivity and Internet Protocol Security (IPsec). Plus, the range features Print Archive, Secure Reset.
Flexible print solutions from Brother
Brother print solutions are exciting packages of innovation designed to make doing business easier. By offering a range of print solutions to help your customers maximise print efficiency and minimise costs, we help you add value to every printer.
Eco-friendly
The DCP-L5500DN 3-in-1 is awarded with the stringent German Blue Angel, Nordic Swan and Energy Star environmental standards. That means that this printer is classed as particularly energy efficient. Also, separate toner and drum mean you can help protect the environment and lower costs at the same time.
Brother DCP-L5500DN - multifunction printer (B/W)
Printer / copier / scanner
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
3500 pages
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
1200 x 1200 dpi
Display
3.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Google Cloud Print ready, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
43.5 cm x 48.6 cm x 42.7 cm
16.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
2 years warranty
Printing Technology
Laser - monochrome
3500 pages
Display Diagonal Size
3.7"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, BR-Script 3, PDF 1.7, XPS, EPSON FX
Automatic Duplexing
First Print Out Time B/W
7.2 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
300 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 40 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 spm (A4) - B/W duplex , Scanning: up to 24 ipm - B/W , Scanning: up to 20 ipm - colour
1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, APOP
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
AC 230 V (50/60Hz)
645 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
7.5 Watt
First Copy Out Time B/W
9.2 sec
Nordic Swan
Blue Angel Compliant
43.5 cm
48.6 cm
42.7 cm
16.4 kg
Shipping Width
54.5 cm
Shipping Depth
52 cm
Shipping Height
64.1 cm
Shipping Weight
19.7 kg
Sound Emission
35 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
