Click to visit BT.com
BT.com
Wishlist
Brother DCPJ152W Colour Inkjet Multifunction Printer
Quicklinx: 8ZFYWS00
Mfr#: DCPJ152WZU1
Essential accessories
The Brother DCP-J152W A4 All-in-One Wireless Printer can print at a resolution of 6000x1200dpi, which makes it ideal for home photo printing. The 1200x1200dpi resoution for copying and 19,200x19,200dpi resolution for scanning means it can copy and scan documents in high detail.
With wireless connectivity as standard you can print and scan directly to and from your mobile device. Print directly from your Apple, Blackberry, Android and Windows mobile devices As this machine is Apple Airprint compatible you can print most common file types from any Airprint enabled application. Most common file types can also be printed from any Google Cloud Print enabled applications. Easily print any of your photos off your mobile phone or tablet by simply pressing print on your device! A fast print speed of 27 pages per minute in mono and 10 pages per minute in colour could make you think that this Brother All-in-One printer is a laser machine! Navigation through the printer menus is easy with its 4.5cm Colour LCD Display Your operating costs can be lowered by using the optional high capacity replacement ink cartridges.
