BT.com
Wishlist
Brother DCP-L2520DW Mono Laser Mulitfunction Printer
Brother DCP-L2520DW Mono Laser...
£124.34
Hurry, only 3 left in stock!
£124.34
Add to wishlist
Delivery
Standard 1-3 working days
Speed up your small office. With this Wi-Fi enabled Mono Laser All-in-one printer, you're free to print and scan from anywhere - compatible with the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct, the DCPL2520DW is one well connected device.
With added All-in-One functions, this machine provides a quick and efficient solution to all small office print, scan and copy requirements. Offering quick print speeds of up to 26ppm and a large 250-sheet paper tray, this compact machine really outperforms its size.
Automatic 2-sided print and optional cost-effective, high-yield toner cartridges help to reduce running costs and waste. For affordability and the freedom of your office, you can't go far wrong with this wireless mono laser All-in-One printer.
Brother DCP-L2520DW - multifunction printer (B/W)
Printer / copier / scanner
United Kingdom
Printing Technology
Laser (monochrome)
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 26 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 2400 dpi
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n)
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 26.7 cm
9.7 kg
Microsoft Certification
Compatible with Windows 7
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
PC Connection
USB 2.0, Wi-Fi(n)
United Kingdom
Standard Memory
32 MB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 26 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, BR-Script 3
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
30 bit
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 26 ppm (A4) - B/W , Printing: up to 13 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, TKIP, AES
Operating System Support
Linux, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 700 pages , 1 x drum
40.9 cm
39.85 cm
26.7 cm
9.7 kg
Shipping Width
56.7 cm
Shipping Depth
51.7 cm
Shipping Height
41.4 cm
Shipping Weight
12.5 kg
Sound Emission
33 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
