BT.com
Wishlist
Brother DCP-J4120DW A4 Multifunction inkjet with A3 bypass tray and Duplex and Wireless
Brother DCP-J4120DW A4...
£124.98
Wireless ready + connect to your mobile device or the cloud
Hurry, only 3 left in stock!
£124.98
Add to wishlist
Delivery
Standard 1-3 working days
A PERFECT FIT FOR YOUR HOME OR SMALL OFFICE BUSINESS
Our latest 3-in-1 A4 inkjet with A3 capability
It's easy to connect to the DCP-J4120DW from your PC, laptop or mobile device thanks to its integrated wireless networking, allowing any users in your office or home to print and scan with ease.
The 6.8cm colour touchscreen lets you connect to popular cloud platform such as Facebook, Google Drive and Dropbox. While you can manage your documents more effectively with features such as A3 printing, 2-sided print (up to A4), and easy scanning and copying.
The optional high-yield ink cartridges can also help lower your printing costs compared to standard yield ink. And rest assured the DCP-J4120DW complies with the strict ENERGY STAR, German Blue Angel and Nordic Swan environmental standards.
Change how you look at office printing. The DCP-J4120DW is a robust inkjet printer designed specifically to enhance productivity. Features such as automatic 2-sided print, connectivity to your mobile devices and A3 printing are all packed into its compact size, raising efficiency without losing valuable desk space.
Welcome to a new age of printing
Key Features
  • Print up to A3, Copy & Scan up to A4
  • Up to 20 mono / 18 colour ipm print speeds
  • Automatic 2-sided printing
  • 6.8cm colour touchscreen LCD
  • Wireless ready + connect to your mobile device or the cloud
  • Up to 1,200 page high-yield ink cartridges
ENHANCED CONNECTIVITY
With built-in wireless networking, the cloud connected DCPJ4120DW ensures seamless connections to your PC and mobile devices. Scan to and print directly from cloud services such as Dropbox, Evernote™ and Google Drive to digitise your paper-based content.
COST EFFECTIVE
High yield ink cartridges capable of up to 1,200 black and colour prints combined with other cost-saving features like 2-sided printing and ink save mode help to lower operating costs.
MOBILE INTEGRATION
Brother's mobile print and scan app provides seamless compatibility with Apple, Android and Windows devices. Print from or scan to your smartphone or tablet using the easy-to-use Brother iPrint&Scan app.
PROFESSIONAL
Ensure that your business is noticed by using the rear feed slot to print documents in A3 size. With a resolution of up to 6,000 x 1,200dpi, your prints will always look professional.
PRODUCTIVE
The DCP-J4120DW comes packed with a range of productivity solutions to help streamline your work, boasts fast print and scan speeds, and has an intuitive touch screen that's easy to navigate.
Brother DCP-J4120DW - multifunction printer (colour)
Printer / copier / scanner
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
215.9 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, photo paper, coated paper, glossy paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, AOSS, Google Cloud Print ready
AC 230 V (50/60Hz)
48 cm x 29 cm x 16.3 cm
8.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
215.9 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
1 sheet
50 sheets
Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 20 ipm - B/W , Printing: up to 18 ipm - colour , Scanning: 3.37 sec (A4) - B/W , Scanning: 3.37 sec (A4) - colour , Copying: up to 12 ipm - B/W , Copying: up to 9 ipm - colour , Printing: up to 35 ppm - B/W fast , Printing: up to 27 ppm - colour fast
1 x USB 2.0 - 4 pin USB Type A , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Windows 8.1, Windows 8.1 64-bit, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
Software Included
Brother ControlCentre2, Brother MFL-Pro Suite, Brother ControlCenter4, Nuance PaperPort 12 SE
AC 230 V (50/60Hz)
23 Watt
Power Consumption Standby
5 Watt
Power Consumption Sleep
1.3 Watt
Direct Printing Specifications
PictBridge
Nordic Swan
Blue Angel Compliant
48 cm
29 cm
16.3 cm
8.1 kg
Shipping Width
56.9 cm
Shipping Depth
24.2 cm
Shipping Height
39.8 cm
Shipping Weight
10.1 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
